Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
[email protected]
SOURCE: Cricut Expressions Machine error
Hope this helps you.
SOURCE: My Cricut Expression keeps turning on and off.
I have one of these machines stripped down on the bench now with this problem. I have located the fault to a power relay which is sealed but must have burnt contacts as it is not passing the power to the machine to power up. I am still looking for a source of 18 volt coil relays with 10 amp contacts to fix this one. If not I may have to modify the circuit to overcome this problem.
SOURCE: My LCD on my cricut
after doing some research i found a lot of problems with the machines purchased this xmas exp the colored ones the best thing is to contact cricuit and see if they will replace them
SOURCE: I have a cricut expression
there is a relay on the under side of the keyboard that goes out. ther is a release on the left side of the keyboard on the cricket expression that lets you remove the keyboard for a tall cutter or something. Turn the keyboard over and take the back off.there is a square area that protrudes from the back of the key board. that's where the relay is. it can be replaced. or bypassed.
