All my details from my past have now been linked with this other person on the police database what can I do
SOURCE: memphis codes
Most scanners require you to program frequencies manually before you can scann them. Your instruction manual will tell you how to do this.
If you need Memphis frequencies, go to these links:
Memphis, TN
http://www.radioreference.com/apps/db/?ctid=2506
Memphis, AR
http://www.radioreference.com/apps/db/?ctid=125
Rollin Cbs
Dean
SOURCE: "No detailed maps found that support routing".
Please click on this link to obtain more information on this problem:
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
SHARCNET-USA
SOURCE: Brake light flickers while driving down the road.
Check the brake fluid. It may be just low enough to occasionally turn the light on as you hit bumps and it sloshes a little. Add a little brake fluid to the reservoir and check the brake pads all around.
SOURCE: 2004 Peugeot 307 keeps popping bulbs
Try replacing the relay switch. Check and see if you have a Relay for the headlights/lights for your vehicle... sometimes the relays can end up bent and corrosion can settle at times...not sure why, but its happened to me several times in different vehicles...good luck!
