Saws Logo
Jay Hines Posted on Mar 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to lay tile - Saws
water heater solar
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Mar 20, 2019
water heater solar
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
217
Points
Paul Carew
Level 3:
  • Master 3,808 Answers
  • Posted on Mar 05, 2018
Paul Carew
Master
Level 3:
Answers
3808
Questions
Helped
1299791
Points
10526
Floor tile wall tile , there are some good video's on u tube that will help
How do you know what diameter saw to use on a wet tile saw. Does the size of tile come into play?
what brand model saw do you have? replace it with the same size. The standard size in 4, 7 or 10 inch. Tile thickness does not come into play. I spend about an hour laying tile across floor and shifting to minimize waste. never cut less than 1/2 tile. Bathrooms hide your cuts behind toilet, and under cabinet toes kick. I use a laser square to keep tile inline if tying into another room. Remove and discard baseboards and undercut door jambs, Use new and painted baseboard, This will let you conceal cuts and leave a nice finish. do not do what amateurs do and lay tile up to baseboard an try to grout between tile and wall, it looks exactly like what it is , an amateur job.
Dec 08, 2018 • Saws
tip
Ceramic tile installation
To Start a Ceramic Tile Project:
1st: Figure out the Size of the Room-Length x Width. This will give you the suare Footage of the Room, and will Determine the amount of Materials You will need for Preparation of Floor before Tile Installation.
2nd: Pick out the size of Tiles, and the Color you wish to Purchase(Decide if it is a High Traffic Area) Tile Comes in different Grades, and if a High Traffic area, you will need a Higher Grade Tile.
3rd: Materials needed for Preparation- Hardy Backer Board(1/2"-3' x 5'). HardyBoard Screws, Unsanded Mastec, Spacers-Depending on Tile Spacing/size of Tiles, 1' x 4' boards. (Tools Needed- Drill, Chalkline, Measuring tape, 3/16 x 3/16 Trowel, 1/4 x 1/4 trowel).
Installation; )Preparation) 1- Apply a 3/16 x3/16 trowel of Unsanded mastecon floor before laying the Backerboard. Screw the Backer Board to the floor recessing screws. (Never have Backerboard meet with 4 pices meet together, off set each piece of backerboard during Installation). After sweeping the room, use a trowel to fill screw holes with unsanded Mastec. Tape all Joints and fill with un-sanded Mastec.(Let Dry for 24 hours).
Tile Installation:- 1st- Sand Mastec used for joints, and screw holes. 2nd- Sweep roome very good and vacuum very well. 3rd- Measure each wall to find the Center Point of the room.(I prefer nailing a board down across one side of the line to keep tiles straight, and butt tiles to the board, and put spacers in between tiles). I use a 1/4" trowel to butter tiles before laying. With using Spacers, buttering tiles, laying tiles.( I prefer using a 2 x 4 and tap tiles across with a rubber Mallet to keep all tiles same heigth). Let One side tiles laid for 24 hours. 4th- Then do the same thing with other side of line.
Finishing Project: Once all the tiles are set, and all spacers removed. Mix up color of Choice unsanded Grout, and follow Manufacturers mixture Specs. Use grout Float and fill Spacing between Tiles. Let dry for 15 minutes. Use bucket of Clean water and Big sponge rinsing frequently removing all Grout from Tiles. Let dry for 30 minutes, and clean tiles again with Clean Water. Let set overnight. Next day, take Clean towel and rub haze off the tiles. Lastly, Seal Tile and grout.
Enjoy your project, and the Satisfaction of doing it yourself. Hope i was some help!!
on Feb 06, 2012 • Ridgid Saws
2answers
Instructions for beginner bathroom tiling
Make sure you get the floor as flat as possible and clean before you start. Steve is right watch some you tube videos first and come back with any specific questions you still have.
Dec 02, 2017 • Home
Do you lay tiles low to high or high to lo?
You want to lay tile in your car or truck? Cowabunga dude.
1helpful
Slate bathroom tile
First clean floor down to plywood. Then buy mastic, notched trowel and tile spacers from hardware store. Lay out tile in the pattern you want by cutting them with a tile saw you rented. take out dry laid tile and mastic a small area and install til making sure you press the tile into mastic. Insert spacer and install next tile.
May 16, 2013 • Home
1helpful
I have crack in my shower floor concrete, would like to fix it before laying tiles and hope it won't be visible after i am done with tiles. I had tiles before wich I am removing now and will instal new...
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Jun 29, 2010 • Plumbing
Adhesive for granite tiles on kitchen counter?
Mortar, go to a tile supply store and ask for the best tile mortar for granite.
Glue is fast and easy but pails in performance to that of mortar.
Replace old vinyl/plastic type stand up shower - I want to convert over using tile. What do i use as a bottom pan i can tyle over?
You could make a base that would be framed up 2x4's and covered with a waterproofing membrane. lay concrete floor, sloped to drain (2piece) and tile. Or use a fibergass base that fits to studs. And then tile walls.
Sep 21, 2009 • Home
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
