Amazon SoulBay SoulBay 12W Universal Muti Voltage AC/DC Adapter Switching Power Supply with 6 Selectable Adapter Plugs, Suitable for 3 V to 12 V Device SoulBay
Hello, Ford -
According to the website eReplacementParts.com, the charger for the Black and Decker Bright Bar WLB26B (DeWalt and Black and Decker part #5140044-94) AC Charger) is no longer available. It has been discontinued.
https://www.ereplacementparts.com/black-and-decker-wlb26p-led-bright-bar-parts-c-4167_4402_202474.html
You may be lucky enough to find one for sale on eBay.
Best wishes.
SOURCE: Black and Decker Battery Charger
Fault Codes
Meaning of Fault Code
F01
Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load.
F02
Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair.
F03
Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual.
F04
Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual.
F05
Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation.
F06
Reverse Polarity
F07
Alternator Output is Out of Typical Operation Range
Operation Codes
I=I=I=I
Battery Reconditioning - (The letters DES will display for the first three seconds)
I-I-I-I
Alternator Voltage Check
OOO
Charger Standby
FUL
Battery Fully Charged
SOURCE: where to get in car charger for evesham 7211
Hi.
I just bought an in-car charger for the 7211 on ebay.
It is 5v with a 2amp flow.
It's not for the mini-USB port on the side but for the dc input hole on the other side.
I've just plugged it into my laptop via the mini-USB port to see if it will charge that way but it doesn't seem to be doing.
Hope this helps.
SOURCE: I lost the charger for the 18v PSO1800 Type cordless drill
Replacement parts in USA from
http://www.ereplacementparts.com/charger-p-100122.html?osCsid=cv3pj4ntur724eevbt3vhfeor4
does not appear to be a UK model.
SOURCE: Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Testimonial: "Thanks RetiredRon, this was the first post I'd seen for the polarity of the plug."
The original charger needed a converter with a min 12VDC 3330mA output. Having a muli-tip Universal Power Supply, I manufactured an adapter from an Inline Receptacle that matched one of the tips and a 2 Pin Polarized Quick Disconnect Cable (check Workman Electronic Products TP-2) This takes some soldering skills and the only thing that is critical is making sure that you have the correct polarity to the correct pin. The +POSITIVE output on the Universal was to the center pin and the +POSITIVE pin on the 26MCP is marked on the Plug Cover as the lower pin closest to the base. I chose the red wire to POSITIVE pin.
