Are there gears in there that I should be worried about
SOURCE: Gear stick
Mini's have had problems in the past with the shift cables coming off or breaking. No worries: the only danger is that you will be stuck in the gear you where in when the cables break. No damage to the car will occur. You should check out the recall notices. Good luck
2002 Mini cvt owner
SOURCE: fiero timing gears
here is a nice description how to replace the timing gear on a 2.5L Fiero:
http://floridafieros.org/osg/timing-gear.html
SOURCE: 1996 Buick Regal Sport - Leaking Plastic Elbow
YOU NEED TO REPLACE THE BELT TENSIONER.
IF YOU BUY THE CARTER BELT TENSIONER AT ADVANCED AUTO, IT COMES WITH: A PLASTIC ELBOW WITH O RINGS, TENSIONER, PULLEY, NEW O RING WHERE THE BELT TENSIONER MATES TO THE ENGINE BLOCK AND NEW O RINGS FOR THE INLET AND OUTLET CONNECTIONS ON THE BELT TENSIONER TO THE HEATER CORE (COST $72).
IF YOU DON'T REPLACE ALL THE ABOVE O RINGS THEN YOU CAN EXPECT MORE LEAKS.
IN ORDER TO REPLACE THE PLASTIC ELBOW YOU MUST REMOVE THE BELT TENSIONER ANYWAY. IF THE BELT HAS SEVERE CRACKS REPLACE IT ALSO.
STEPS:
-REMOVE BELT
-DISCONNECT BATTERY
-DRAIN ANTIFREEZ AND DISCARD
-REMOVE ALTERNATOR
-REMOVE BELT TENSIONER
-REMOVE PLASTIC ELBOW (DO NOT ALLOW BROKEN PIECES PLASTIC OR DIRT TO GET INSIDE THE ENGINE WATER CAVITIES.
-CLEAN ALL CONNECTION WHERE O RING WILL MATE.
-TO REASSEMBLE GO IN REVERS ORDER
-REFILL THE RADIATOR WITH COOLENT 50% MIX USE THE 5 YR GUARANTEE TYPE.
-MAKE SURE THE COOLENT RESERVIOR IS
FILLED TO THE HOT LEVEL MARK.
-RUN THE ENGINE UNTILE IT IT REACHES THE 1/4 % TEMP MARK ON THE TEMPERATURE GAUGE THEN TURN THE ENGINE OFF AND OPEN THE BLEED SCREW ON TOP OF THE THERMOSTAT HOUSING.
ALLOW THE AIR TO EVACUATE, YOU WILL SEE COOLENT COME OUT THEN CLOSE THE BLEED SCREW.
-BE VERY CAREFUL WHEN YOU OPEN THE RADIATOR TO REFILL TO THE TOP.
-REPEAT THIS ONE MORE TIME.
-RUN THE ENGINE AND KEEP YOUR EYE ON THE TEMPERATURE GAUGE' IF THE TEMPERATURE GOES BEYOND THE 1/2% MARK, SHUT DOWN THE ENGINE QUICKLEY AND LET THE ENGINE COOL.
THIS MAY TAKE HOURS TO COOL DOWN BUT THE COOLING SYSTEM WILL TURN FROM PRESSURIZED TO VACUUM AND DRAW COOLENT FROM THE RESERVOIR TO REFILL THE SYSTEM.
YOU WILL NOTICE THE LEVEL DROP IN THE RESERVOIR .
SOURCE: Body Cladding for 99 Grand Cherokee Laredo
there is a company called quadratec they make cool stuff for jeeps. go one the web and look it up. cherokee's Grands and wranglers. they have alot of stuff to make the jeep look good. and replacement panels and plastic and diamond plate trim. enjoy.
This can be repaired no problem. Just clean the area where the leak is and drop superglue on it and then sprinkle baking soda on it. It will harden immediately and is very strong
