SOURCE: Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
SOURCE: Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
SOURCE: Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
SOURCE: H4 error on Sharp SF 7370
The heater lamp isn't coming on either because of blown heater lamp or thermostat reset itself . Clean the thermistor and replace any of the above defective part.Then press C, 0, 0, C and press 14 press READY.
SOURCE: Sharp SF 2114 H-4 Error: Fusing Unit Not Heating
Replace fuser lamp and check the condition of thermistor and rectify.
