Toys Logo
Rosewoode Watts Posted on Feb 24, 2018
My 2 year old granson washed his tablet under water and now we can't get it turn on
I have none
Roy
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Jan 20, 2019
Roy
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
4558
Points
56
DO NOT USE RICE. It will cause more damage. If it will it will not turn on it will most likely be the battery. It’s worth a shot for an expensive tablet but the cheaper tabs would be best replaced.
  • 2 more comments
  • Anonymous Jan 20, 2019
    time for water proof PC
    good luck there.
    maybe a waterpoof cell or tablet .
    or like me,at 2 got cap gun.
    and sling shot, and cork gun and far far worse.(soon a chem set)later anything with gears.
    omg,
  • Roy Jan 21, 2019
    Yes it will Steve. Maybe you should read up or try it yourself on one of your electronics. Rice will not do any good. It does not work. Rice will do more harm than help. Do not use rice to dry out electronics.
  • Anonymous Jan 22, 2019
    in shop, not home
    we separate the LCd screen , cleaned carefully by hand (towel and blow dry).
    and battery hand towel cleaned.
    the keyboard may be a total loss
    and flush the electronics is near pure alcohol
    this absorbs water.so well.
    and then use oven heat to dry that.
    after all that labor, you go broke.
    stick to toys for kids, ok?
    or lacking nasty crumbly rice? LOL
    buy a large bag of silica gel, desiccant.
    See in stores with gun safes !
    it's sealed in rag bag. NOT loose.
    put that in larger plastic zip log bag wit the Tab SEALED.
    put in a window self. in the south side of house.
    OR PUT IN THE NASA CENTRIFUGE IF YOU HAVE PERMISSION.
1 Related Answer
Anonymous
  • 15 Answers
  • Posted on Feb 02, 2010
SOURCE: 17 year old maytag washing machine leaking water
The pump is at the right front. When the seal goes bad the pump will leak down the shaft. Check the hoses too.
Beko dishwasher DW603 6 years old, its sometimes not washing properly, I find the tablet undesolved in the bottom, also some times not drying pots. sometimes it works fine.
If the dishwasher is undergoing short programmes and low-temperature washes then your dishwasher may not allow for the tablet to fully dissolve leaving some remaining tablet left behind. Another reason why the tablet may not be dissolving is because of the water hardness of the area you live in as the tablet may take longer to dissolve in the water.
I have a Nordictrack X9i treadmill and it is less than a year old. When I went to turn it on it booted like normal, but then went to a phone/tablet android screen and none of the buttons are working on the...
I would call who you bought it from and get it replaced under warranty as it's less than 1 year old.
If that won't happen, check the manufacturers warranty and get in touch with their service department to arrange a replacement or repair
1helpful
Old christening gown 100+ years gone yellow how do I clean ir please
I would wash it the same way as one washes natural net curtains. Carefully fold the garment up in a clean cotton/muslin sheet making sure it it pinned down so not to move and immerse in warm detergent water NONE BIOLOGICAL!
Soak for a few minutes and press through the outer cloth to avoid damage to the garment. Watch out for the pins!!!
Rinse and wash a few times or until the water is clear.
Remove from the cloth cover and lay to air dry in a warm place.
I know this as I watched a Victorian programme a few years ago regarding cleaning the old fashioned way with old fashioned garments and the programme covered an old dress.
Hope that helps.
1helpful
I have a roper,1 year old .The water will not stop running on spin cycle or when stopped ? Have to turn the water valve off ?
First off, you say one year old. If it is one year or under, it has a one year warranty and you need to contact your nearest authorized whirlpool repair. Your problem is that the fill valve where the two hoses fasten onto needs replacing. You can go to your nearest parts house with your complete model number and they can help you get the right part. Thanks
3helpful
The machine is not operating; has run through part of a cycle but has not drained. We have tried to restart it, but it is not moving through any of the cycles. Power is on as we can hear it. It is a...
drain the water with the emergency pipe at the bottom inspection flap. once empty unscrew the pump chamber cover and remove any blockage make sure the impellor down the chamber will turn, you need a long crewdriver or similar to reach it . if none of this a new pump may be needed.
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
2answers
Hotpoint Aquarius DWF31
to isolate fault,remove bottom front panel,turn off main water,put a tray under machine, remove inlet pipe frompump at front of machine. for a second to see if you have flow that far. If so trouble is in machine. Dig the filter out of th pump entry .It could be blocked
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
