SOURCE: Toshiba TZ55V61 having prob. w/red,yellow lights
Convergence issue...replace STK392-110 IC's on small PCB
mounted by itself above power supply....................T.
SOURCE: 55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
SOURCE: replaced lamp on Hitachi 50V720, still have flashing red light
Just make sure the Box (Lamp Enclosure) is pushed in firmly on both sides, left and right. Left side to hit the power connection and Right side to hit the little relay switch, Must be flush against that back side. It happened to me and I was kicking myself in the ***, a entire weekend went by with a brand new lamp sitting in the enclosure but not completely set in correctly with a flashing red light.
SOURCE: My Red Blackberry Curve 8310's Indicator light keeps flashing
you would have to reload the OS back to the device from the blackberry desktop manager software (application loader) but basically your phone is fried.
