Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: i need the 3-digit code for my sharp tv code
Here is a link to an extensive list for your 3 digit code to use with Chunghop
preprogrammed remote controls it includes scanned copies of 6 different
versions, plus a cross-reference chart. I hope this helps, if it does please let me know by giving me a yes helpful rating~
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=chunghop&dv=universalremote&md=chunghop3digitcodescollection&kw=&st=&ar=&dt=&so=&pg=1&file=others/chunghop/chunghop-3digit.zip
SOURCE: i need keyin remote rm-133e,tv code for nec tv
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web
SOURCE: ihave keyin rm 133e universal remote and ineed a code panasonic tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
