SOURCE: 1996 Grand Cherokee keyless entry problem
That remote should not be able to be programmed by you, it needs to be programmed by the dealer using their computer. I know that some later and earlier models can be programmed by the user, but I did some research on this as i have a 96 as well and it seems the 96 was a dealer computer thing. If you in fact bought the remote from the dealer they should be willing to program it for FREE. Otherwise I was given a $30 estimate for the programming.
SOURCE: remote controls for factory alarm system are not working.
Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the passenger door module (PDM). • The PDM will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • The panic button should still operate normally when the system is out of synchronization. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the PDM, perform the following steps: 1. Stand within 1.5 meters (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds. The door locks should cycle in order to confirm resynchronization.
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
SOURCE: remote is not working will the sensor go out programed new remote and still will not work?
Stop buying ilo tv's, is the best solution i can offer.
SOURCE: Cool Start model CS34-II TX manual
the problem with this remote is that it is used for a bunch of different models you have to look under the dash and get your unit model number and then check the crime stopper manuals for that units number you do this at www.crimestopper.com under support tab click on manuals and manuals again and then choose the model number you found under your dash
