Yamaha 2008 RS Vector Logo
m
marc neely Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there anyway to test cdi unit on yamaha 540 vmax snowmobile
vtrktrmn
Level 2:
Sergeant:
  • Expert 201 Answers
  • Posted on Mar 04, 2018
vtrktrmn
Expert
Level 2:
Sergeant:
Answers
201
Questions
0
Helped
107301
Points
569
Service manual give complete details in testing CDI unit
1 Related Answer
ibm2065
Ernest
  • 489 Answers
  • Posted on Feb 03, 2018
SOURCE: itether switch yamaha 540 vmax snowmobile . is circuit normally closed when is connected
Should be normally open and shorts plug to ground when you fall off.
1996 Yamaha Vmax XT 600 snowmobile. How can I replace speedometer cable?
Unscrew it from the back of the speedometer and follow it back to where the cable terminates at the hub of the track. Undo it there and replace it with the new one.
https://www.google.com/search?q=1996+Yamaha+Vmax+XT+600+snowmobile.+How+can+I+replace+speedometer+cable
Itether switch yamaha 540 vmax snowmobile . is circuit normally closed when is connected
My snowmobile vmax 600 will not go over 25 mph. what could the problem be
First you need to determine whether the fault is caused by poor engine performance or whether it is being held back by excessive friction in the driveline.
97 VMAX is stuck in 1st gaer
Does It Have A Vacuum Modulator On It For Shifting Gears? If So, Have It Checked Out
1995 yamaha vmax 600 backfires wont start
if it is backfirering sound like timing is out of spects
My 1997 yamaha xtc 600 vmax is back firing and wasnt doing that before
YOU HAVE TOO MUCH FUEL GETTING INTO THE ENGINE,USUALLY CAUSED BY A FLOAT SETTING ISSUE IN THE CARB
I have a '97 yamaha vmax 600 with 17500km and suddenly all my bulbs burnt out. I changed the voltage regulator and it is still doing the same thing. Could it possibly be a CDI problem?
Which bulbs are the ones burning out? They may have a short on a common wire that causes them to burn out. You should probably also check the stator to make sure it is not shorted out or producing higher voltage than it should. This can also cause bulbs, batteries, and regulator/rectifiers to burn out.
1helpful
95 Yamaha vmax 600 (new belt is too tight)
sounds like the belt is wrong size. double check this,and if it is correct size make sure the secondary clutch is closing all the way.
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Bob G
Sean Wright
Sean Wright
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
