Computers & Internet Logo
H
Hayley Mythen Posted on Jan 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dont want to show when im on my device,how do i turn that off
james laughton
Level 3:
  • Computers & ... Master 2,195 Answers
  • Posted on Jan 31, 2018
james laughton
Level 3:
Answers
2195
Questions
Helped
411688
Points
6636
You can turn off the WiFi and data connection and no one will know you are using it
if you want to use social networking and not show as online not going to be possible
Nextbook flexx 11" --how to turn off internal mic so external mic can work, or can you do that? my externl mic isnt woring
Hi, you can change this setting in the control panel, would you like me to show you how remotely?
1helpful
2answers
It dosent show that im receiving a call on myzte phone
Try to set different ringtone on your device and also check whether the volume is maximum or not. If all these are working fine then try to reset your phone to factory defaults.
Apr 06, 2013 • ZTE Warp
How to unbrick a android huawei835
This How To UNbrick your huawei m835 phone step by step.
To tell if your phone is bricked it should only show just the huawei logo or the android logo when you try turn it on and no key combination works to boot into recovery, if u can boot into recovery, dont use this guide.
1) Click This Link to download Huaweis Oringinal Software. ---->HUAWEI M835 - Huawei Device Co., Ltd..
a)Click on the software tab and select the first file there. It may or may not show an error but dont worry just refresh the page and the download will start.
2)When its done, open the M860V100R001C153B251SP03 folder (the folder you just downloaded).You should see another folder called dload and some instructions.If you dont understand what im saying then click the instructions in the folder.
3)Connect your SD card NOT your m835 phone into the computer.
4)Then drag the dload folder any were on the SD card.
5)When thats done take out your battery and put it back in.
6)Press and hold Volume Up + End Call + And The power button at the same time.(i know this sounds wrong but it works)
7)Its Gonna Update your firmware.
8)When its done Turn On your device and the screen that popped up when you first got your phone should appear.
9)Continue with that and BAM your phone is now UNbricked.
Hello im trying to set mysamsung sp8004h harddrive as a slave i dont know the proper pin settings it shows in the bios and device manager what do i do.
If it shows in the BIOS as a "slave", then you have the correct settings. If it does not show, or if the other drive on the same ribbon-cable does NOT show, then you have the wrong setting.
2helpful
Theres a delay when i play my xbox 360, why? I have a hdmi cable, im not "online".. but theres a second and a half or so delay when i move the controller till it shows on the tv, help please, both are...
go to your picture menu and go to advanced video then go to DCM and turn it off. it should work i had the same problem if that dont work then try turning off the dynamic contrast and adaptive contrast along with the DCM. if that dont work then im sorry.
Wont Charge
dont purchase that type of mobiles...... u had better to purchase nokia, lg , mobiles.. thank u
1helpful
How Do You Open the USB port
Look in "My Computer" or "Windows Explorer" the device may show up as a drive or connected device.
2answers
95 jeep cherokee
Your problem is in te combination switch (the light switch that turns the lights on). Replace it and it should be happy again.
2helpful
2answers
PSA250/17 doesn't show the songs that I have put on it!
I was having the same problem with my PSA250/05 but found out how to resolve it.
As the PSA250 converts the files into it's own naming algorithms simple dragging and dropping mp3's work work as the device doesn't recognise them.
Inside musicmatch Jukebox you will find a portable device options section. In here under one of the options you'll see the mp3 device which is in a drop down box. If you click this box you'll see that you have another option for Nike + Phillips, select this option and now add your tracks.... All should be fine.
MOPSTER
Grand Canyon Tech
Grand Canyon Tech
