I want to give a solution about your problem about turning on wireless radio feature on your hp officejet pro 8620 printer.
The solution is just download HP ePrint Software. You can download at link below
HP Officejet Pro 8620 Driver
SOURCE: HP Officejet 8500 Wireless All-In-One Control Panel Faceplate Err
>the error says it, what you need to do is check if the faceplate the plastic thing which covers the printer buttons is attached firmly.pry open the side of it rmove the faceplate then attched it back again.
SOURCE: how to i wirelessly connect my laptop to my hp
Download the manual for the printer from here and check pages 100, 129, and 130
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
SOURCE: HP OfficeJet Pro 8500 A909 does not print
i cant print what happening. Its telling me to load paper but i have paper in slot. This started happening after a paper jam.
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Testimonial: "superb"
SOURCE: I want to run my
There is a button, on the printer, usually. This printer should be network cable attached and not USB. USB requries a host system and that host needs to be running and have sharing settings set to share.
MUCH better to connect the printer directly to your router.
