Air Tools & Compressors Logo
Elvis Krvavac Posted on Jan 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a vsd fault 8 on my Nirvana n110 kw air compressor. What do I need to do?
vince
Level 3:
  • Master 2,530 Answers
  • Posted on Jan 22, 2018
 vince
Master
Level 3:
Answers
2530
Questions
0
Helped
748803
Points
8845
  • Elvis Krvavac
    Elvis Krvavac Jan 22, 2018
    Vince thaks for the help, you are the man
1 Related Answer
hassan_abada
abadade hassan
  • Posted on Oct 23, 2015
SOURCE: IR Compressor sl.No N37
HELLO I nedd ingersoll nirvana vsd fault diagnostics manual.
thanks
Ingersoll Rand Nirvana N160, fault messages: VSD 22 and VSD 33. What could be these faults? How can we repair it?
VSD Fault 22 -Current Overload, occurs after the drive motor has been in an overload condition for a period of time.
VSD Fault 33 -Rectifier Temperature, occurs when the input bridge heat sinks is greater than 194*F
2answers
Plase help!VSD fault 2 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw
Vsd fault 2 is a current imbalance. Check your current readings and compare them to those on the intellysis display they should match, also check for a imbalance in amps. After that it gets more complicated using board diagnostics etc
Please!!!VSD fault 7 and VSD fault 1 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw. thanks!
Vsd fault 7 is a fault with the hall effect sensors inside the motor, more than likely they will need replacing.
2answers
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
these compressors are costly even the parts to maintain.I would first check if you cooling fan for the vsd drive is working which is located in the electrical panel of the compressor.A failing fan or one that has failed would cause this fault
1helpful
2answers
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
Ingersoll rand nirvana problems vsd 1
Vsd 1 fault is over current, check if motor turns ok, if this is ok it could be a number of issues that will need to be diagnosed by an Ingersoll Rand technician.
Ingersoll rand nirvana problems vsd fault 0
VSD Fault 0 -DC Bus Over-Voltage
VSD Fault 1 -Over-Current
Top Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
