Fish Logo
F
Fred Gregory Posted on Jan 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you keep several geckos in a large converted fish tank
paul wilson
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 52 Answers
  • Posted on Jan 02, 2019
 paul wilson
Expert
Level 2:
New Friend:
Night Owl:
Answers
52
Questions
0
Helped
18294
Points
103
Yes, but according to future growth size, spaced so as not to be overcrowded as the grow and according to their food availability.
1helpful
How many gecko lizards could I keep in one tank
Two but not both male ,as males fight ,also depending on there size and space available in tank.
Jan 21, 2018 • Baby Gear
My betta fish is not eating. I placed a holiday disk in his tank for food while we were away this weekend.. Just got home and the water was extremely cloudy
I hope you did a big water change right away. The very first thing to do, any time there is a problem with water for fish, is to change at least half of it right away. If you have dip strip tests, test some of the water you change to find out if any readings are too high, but do the change first. If you don't have tests, you should consider getting some, they are the only way to tell if the water has too much ammonia, nitrite or nitrate for fish safety.
Cloudy water often means a bacterial bloom has happened, which isn't always dangerous to the fish. But sometimes they can be the result of a rise in ammonia. All fish produce ammonia as part of their respiration and all organic waste, which is broken down by bacterial action, also produces some ammonia.
For the future, It is MUCH safer to simply not feed your fish if you are going away unless perhaps you are trying to raise valuable fry. But most tanks of fry would also probably survive if their tank is provided with large masses of live mosses and floating plants. These provide minute food resources, infusoria, bacteria, algaes, which fish can pick from the plants. Plants, of course, need enough light so they don't die off.
For sure, unfed fish will get hungry, but healthy fish will not starve to ***** in a short time. Most fish can do fine for a week and I leave mine for two and three weeks if I must and so far, nobody has died. During an emergency, my fish survived for over a month without any attention at all, far from ideal but it could not be avoided. Those fish were living in a heavily planted tank and the plants provided food resources. It also contained shrimp and live scuds the fish could eat, though they didn't eat them all.
Even an unplanted tank, if not over-stocked, should be ok, unfed, for 5-7 days, so long as the fish are all healthy and similarly sized. Tiny fish are likely to be eaten if their tank mates are big enough and hungry. If possible, put the tank lights on a timer so the day/night cycle continues while you are away. Full-time darkness won't kill them but is probably not much fun for them, either.
Fasting fish also helps avoid potentially serious water quality problems that uneaten food and fish wastes may cause in a surprisingly short time. Many keepers fast their fish routinely, one or two days a week, which is thought to mimic the erratic availability of food in the wild.
Having living plants in the tank is very useful; they use up ammonia and nitrates and provide interest, shelter and resting places for the fish. Water changes serve to keep all toxin levels at safe levels. Nitrate should not test over 50 ppm at most, 10-20 is best. Ammonia & nitrite should always be ZERO. If any levels are over these, big water changes are the only remedy.
Any fish's tank, including that of a Betta fish, should have a filter of some kind. If it does, changing 50% of the water weekly is what I have found works out for the best. Filters convert ammonia and nitrite to nitrate, the least toxic
Sadly, it's still popular to keep Betta fish in bowls without filters. It's a long way from ideal, but if water changes are done diligently, the fish may be ok, though it often ends up chopping a year or more from their life span. Without a filter, 50% of the water should be changed THREE times each week. That's a lot more changes than most advisory sites will say, but fresh, clean water is the single best friend any fish will ever have living in captivity. Make sure the fresh water's temp' is within a degree or two of the tank's temp' when you change it. Use a siphon or turkey baster to suck up fish waste from the bottom at least every other week, if not more often. Don't remove the fish when you do these maintenance tasks because that can be a lot more stressful than leaving it in.
Never feed Betta fish any more food than they can consume within a maximum of about ten minutes. Many of them tend to be very slow or picky eaters, so they need more time than most other fish species. Remove any uneaten food after a half an hour.
Mar 20, 2017 • Fish
2answers
Aquarium water is cloudy
This can happen and will generally clear with time, if you are concerned do a water change. I find that this treatment is more hassle than its worth, if you have a suitable filter seachem denitrate is a good alternative, or he aquarium pure balls.
What are the heating requirements for a leopard gecko?
Leopard geckos, like most reptiles and amphibians, do not produce their own body heat internally. An external heat source will help them with digestion. This type of lizard obtains heat from their undersides, so the best heat source would be an under tank one. You should look for a heating mat that will cover between 1/3-1/2 of the tanks surface. Try to keep the tank temperature between 84-88F.
How many fish can I put in my 25 gallon aquarium?
A good guideline to follow is for every one gallon of water you can keep one inch of fish. Take into consideration that after rocks, plants and decor the amount of space is less. Lastly, you should keep in mind how large the fish will grow. It is very important that you do not overcrowd your tank.
Jul 31, 2012 • Fish
2answers
Does an aquarium filled with goldfish need a filter?
Generally speaking, goldfish can survive in a fish bowl orsmall tank without a filter. However, ifyou have multiple goldfish in one tank, they would probably live longer andhealthier lives with a filter. Filtersare beneficial because they clean the water and keep it balanced. The fresher the water is, the healthier yourfish.b>
May 13, 2012 • Fish
Which is better for my fish tank, one large heater or two small heaters?
It is better to have two small heaters than one large heaterin your aquarium. This will make itharder to overheat the tank before you realize there is an issue. Here is a YouTube video that shows what happens when youoverheat your tank:http://www.youtube.com/watch?v=7NN2r_rpbyM
May 13, 2012 • Fish
My fish tank air pump broke and I think my fish aren't getting enought oxygen because of it. Should I buy a new one or can it be fixed?
Technically, it can befixed but if it happens once, it will likely happen again. You should buy a new one as they aregenerally pretty cheap. In the meantime,fill a large bowl with water and place the fish there. This will allow them to get some fresh oxygen. While the fish are in the temporary container,get rid of all of the water in the tank. Then, refill again with new, oxygenated water. I wouldn't leave them in this environment formore than a day before you purchase a new air pump.
May 13, 2012 • Fish
How do you convert the bassionet to a chair stroller for the gecko
There is a manual on their web site for you to view or download. Here's the link. Hope it helps!!!
http://www.bugaboo.com/
Top Fish Experts
Keith
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Fish Expert? Answer questions, earn points and help others
