Televison & Video Logo
Eddie Pruett Posted on Jan 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I access the factory service menu on an LG 55 in. tv model 55LB6100-UG?
louisnz
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 21, 2019
louisnz
Contributor
Level 1:
Answers
Questions
0
Helped
4007
Points
12
@jamesdoug70 jamesdoug70
hello sir i think you are the only person whom i looking for>>> i have the same issue in my LG 50 3D tv i have changed the bast light LED strips, and i am looking for reset the blinking light.
i there another way to enter the service menu, i am tried looking in the internet for that. my tv model : 50LA6230 thanks a lot in advance .
Dennis
Level 3:
Top Expert:
  • Master 1,057 Answers
  • Posted on Jun 21, 2019
Dennis
Master
Level 3:
Top Expert:
Answers
1057
Questions
Helped
440525
Points
13558
Https://www.lg.com/us/support-product/lg-55LB6100
5 Related Answers
Anonymous
  • 790 Answers
  • Posted on Mar 11, 2009
SOURCE: TOSHIBA MODEL MV13M2 NO MANUAL, NO FACTORY REMOTE
HI
Yes you can set the menu function if have menu button is there!
Thanks!
Anonymous
  • Posted on Jul 13, 2009
SOURCE: access service menu lg rear projection tv
I want enter the convergent net code
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Dec 03, 2009
SOURCE: WHERE CAN I DOWNLOAD USER MANAUL FOR LG 32 TV
you can get it right from LG and they are free in pdf format
Anonymous
  • 52 Answers
  • Posted on Apr 22, 2010
SOURCE: can the service menu for the LG 52sz8d dlp tv be
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Anonymous
  • 5 Answers
  • Posted on Nov 07, 2010
SOURCE: TV service menu
your tv service mode press tv manual (ok) button and remotes (ok) button at the same time. you wants to press both the buttons at same for fue seconds then service mode open
1helpful
LG tv screen is flashing, model 55LB6100. How do I correct the problem
try this youtube video not saying it will help you with your fault but have a look and see if it does.. Flickering TV Screen Repair LCD LED TV Picture Image Flashing...
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
1helpful
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
1helpful
How do I access the lg 55la6200 service menu?
you need a service remocon to do this there is no other way
(I mean there no other way pushing buttons etc )
How to clear lg model la74 sistem memory
You mean, that you want to set the TV to its factory reset, I assume. If so, you have to enter its service menu option to do this. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service menu entry, adjust and exit procedure to many popular brand TVs are given.
The word "Factory" has appeared on the screen in red
Hi.
Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
1helpful
3answers
4helpful
4answers
Hidden or Service menu
thank of you but i need access to menu service please help me
please mail key to access to menu service
thanks of you
57helpful
7answers
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
