Hello, my husband is working on a big container ship and they have a Skanti VHF 3000. When running the selftests they get an error code 0401. Does anyone out there know what this means? Thank you
A copy of the technical manual can be downloaded from here: https://www.scribd.com/document/374651775/Skanti-DSC-3000-VHF-Tech-Manual
SOURCE: Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
SOURCE: Error Codes P1684 and P0340
P0340
Camshaft position sensor circuit
P1684
means the battery was disconnected(or had been drained to a low voltage) recently.
SOURCE: KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
SOURCE: WHAT DOES FAX ERROR CODE 358 MEAN THANK YOU
