If you shine a flashlight on the screen can you see that theres a picture on the screen but your just not seeing it because of the dead backlights? Most of the time, when there is sound but no picture its failed backlights, this can be a few different things, a failure in the power supply, a failure in the LED backlight driver board, or the LED's themselves have failed. Your only option is to take it to somewhere that can repair it, or toss parts at it until it works, or just toss it and buy a new TV. Most TV's made today are not really designed to be repaired or repairable. But someone with enough skill and experience can usually fix that issue, i do it all the time. But you have to consider the cost of repair versus a new TV, they are so much cheaper now!
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: 47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
T-con board and/ or main board. T-con controls the picture elements and the main board sends the picture signals to the T-con board
SOURCE: Model 50LA6970-UE LED. Has sound, but why no picture?
Hi Paul i have the same problem how do you fix it?
