SOURCE: 1982 kawasaki 550 stand up ski-doo,starving for fuel
fuel pump ? checked pop off presure in carbs?
SOURCE: removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
SOURCE: hOW TO ADJUST tyrolia SL 100 ski bindings
With click bindings on ski's or snowboards it's best to take to authorized service because if you adjust the release to work with to much or to little pressure your gonna end up dropping into a powder run and instantly losing your skis or getting hurt when they don't release under lot's of pressure plus it's based on factor's such as your weight. But you might be able to hit up the service tech to show you how to adjust them yourself so you don't have to pay, and you could probably find a manual on-line but I'm recommending to go to the tech.
SOURCE: I have 95 Ski-doo formula z 583 and last weekend i
check the fuses?if not then there must be a burnt wire someplace close to the exhaust manafold ,either that or your selonoid is burnt out.
