Very first thing. If it won’t turn on, unplug it, and check the cord....especially if you have, or have had, a rabbit that has already chewed through every other wired devices you have ie: TV, satellite dishes, DVD players, other electrical cords.
I got my humidifier year before last and only used it a few times that year. Our humidity was fine until now, so the humidifier was still new as far as I was concerned. I checked every online help suggestion before I remembered Buster. Sure enough....exposed and partially chew wiring. I thanked God that I hadn’t been shocked.
Thank you, Daddy, for teaching this 70 year old grandma how to splice wiring and install other electrical wiring when I was a teenager. I miss you so much.
CAUTION: UNLESS YOU KNOW EXACTLY HOW TO SPLICE WIRING DON’T THINK YOU CAN FIGURE IT OUT. TAKE YOUR APPLIANCE TO A SPECIALIST TO GET A BRAND NEW WIRE PLACED ON YOUR APPLIANCE. I CANNOT EMPHASIZE THIS ENOUGH. IN FACT, TAKE IT TO AN ELECTRICIAN ANYWAY.
SOURCE: tank is broken on Honeywell HCM-560 humidifier.
you type in on the internet. www.appliancefactory.com
in the search bar type in your model number. it might take a minute to load but you will have 3 pictures that come up. click on any of them and scroll down alittle until you see water tanks. you can order them there.. or if youdon't want to go that route you can always try local hardware stores to see if they have it as well.
SOURCE: Our HCM-640bw Honeywell humidifier will leak water
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
SOURCE: I can't find replacement filters HAC-700-TGT for
Hey there - I had the same problem in Maryland. However I found the replacement filters on iallergy.com.
