i
isaac afoakwa Posted on Dec 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to punch in 234 degrees, 23 minutes 24 seconds on the fx-83gt plus casio calculator
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Sep 22, 2018
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4674830
Points
21596
Look for the DMS key (degree, minute second).
5 Related Answers
Anonymous
  • 1126 Answers
  • Posted on Sep 24, 2009
SOURCE: I need to know how to set the Casio fx-9750ga plus
Page 14 in Chapter 1 listed here.
http://support.casio.com/pdf/004/fx_plus_chapter01.pdf
Anonymous
  • 3 Answers
  • Posted on Dec 07, 2010
SOURCE: hello there. I'm having some
try changing you calculator to Degrees it should be the original setting, this can be done usually by removing the batteries or hitting a clear all memory on calc and it should be set to degrees. The reason you are getting "0.4553" is because it is in the radian mode (usually seen as RAD) so easy fix its not your calc its just an operator error.
Testimonial: "tnks a lot! "
MiB8888
  • 457 Answers
  • Posted on Jan 10, 2011
SOURCE: The Tan, Sin and Cos
Press [SHIFT] [MODE] [3] to switch to degrees.
MiB8888
  • 457 Answers
  • Posted on Feb 26, 2011
SOURCE: i can't find the EXP button on my Casio fx-83GT
Your question is slightly ambiguous.
If you refer to the exponential function (power to base e = 2,7182818...), the key sequence is [SHIFT] [ln]. (rightmost button column, two rows below the ON key).
If you refer to a key allowing to enter powers of 10, like in 3,14 x 10²³, see the button labeled
its located in the bottom button row, center column.
  • 102366 Answers
  • Posted on Mar 16, 2012
SOURCE: Hi there, I have a Casio fx-83GT Plus. At the moment when I do a sum 0.009x0.009 (for example) it gives me an answer of 8.1x10 to the power of -5. How do I get the calculator back to just giving '
Press SHIFT MODE 8 2 to select the Norm2 display mode.
Be aware that the calculator will switch to scientific notation if the magnitude of the number goes above 10^10 or below 10^-9.
Can you do the highest common factor on an fx-83GT PLUS casio calculator
The calculator has no application that will find the highest common divisor (or HCF) but that should not be difficult to do by hand.
Decompose the first number in prime factors. If a prime factor is repeated use the exponent notation: That helps
Decompose the second number in prime factors too, using the exponent notation.
Now look at the two decompositions. If a prime factor is present in both decomposition it must be in the HCD /HCF, with the smallest of the two exponents. Do that for all prime factors
Example;
(2^5)*3*(5^4)(7^3)*11
(2^3)*(5^6)*(11^2)*7
The prime factors that are present in both decompositions are
2, 5, 7, and 11
From the two decompositions select the smallest power of each
2^3, 5^4, 7, 11
The highest common divisor/Highest common factor is
(2^3)*(5^4)*7*11
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
1helpful
Casio fx-83GT-plus how to convert binary to hexadecimal
Sorry to be the carrier of bad news but the Casio FX-83 GT Plus does not have a baseN calculation mode. You cannot do any arithmetic in binary, octal or hexadecimal numeration.
1helpful
Casio fx-83GT plus how to convert binary to hex
I have just changed from using a Casio fx-83MS to a fx-83GT Plus. Is there a way of displaying a comma between every third whole number?
I do not think that Casio scientific calculators have the possibility to separate thousands, millions etc. The Sharp have that feature.
Mod operation in fx-83gt plus
Like many other Casio calculators, the fx-83GT Plus doesn't provide the modulus function. You have to do it the hard way.
To calculate 19 MOD 10 (which is 9, not 10 as you state in your question), first divide 19 by 10 and note the integer portion of the result (in this case, 1). Then subtract from 19 the product of 10 and the result of the first step. The result of the subtraction is the modulus. 19 - (1*10) = 9.
Can't change from standard form on my casio fx-83gt plus
There is only one key to toggle between display formats: the S<>D key. Pressing the key repeatedly will cycle through all available display formats.
11helpful
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
