Question about Summit Refrigerators
Summit refrigerator top freezer model FF1625SS evapator drain hole keeps icing up and there is a wire to transfer heat to drain inlet.
This has happened 3 times now and the drain is clear and not restricted. We have like 4 of this model refrigerator in the facility and 3 out of the have all about the same time has started to have this same problem. I believe it must be the insulation getting old and making drain water to freeze around the inlet of the drain hose. All 3 of these refrigerators have the wire from the evapator to transfer heat to the drain hose inlet. Time for a new refrigerators?????
    Top Expert:
  • Summit Master
  • 9,906 Answers
Bad heater element on drain
Posted on Jun 15, 2018
    Habit-Forming:
    Scholar:
  • 99 Answers
Hi, One of the most common problems with frost-free refrigerators (and often with upright frost-free freezers) is drain freeze up. This is usually caused by the defrost drain clogging, then freezing. On older units, it can also happen when the insulation (usually open-cell Styrofoam) around the drain gets 'water-logged', as it often does over the years, causing ice to build up inside the drain.
The first symptom, at least in top-freezers, is usually water under the crisper drawers, on the floor of the refrigerator section.
In side-by-sides and upright freezers it'll appear as a nifty slab of ice on the freezer floor, eventually running water out onto the kitchen floor.
These are quick and easy to make. Just cut a piece of #12 copper wire (strip from regular 12-2WG 'Romex' household wire) about 6 inches long and bend it around a 1/4 inch round rod. A screwdriver shaft works well for this, but any 1/4 inch dia. piece of metal will do.
Now when your refrig or freezer drain clogs and you find the trough under the evaporator full of ice, here's what you do.
Clear the
ice, open the drain (use hot water in your one gallon pressure sprayer and a wet-vac, and hang this little piece of copper on the defrost heater, so it extends down the drain. On most units, this is a black rod under the evaporator coil. Some use a radiant heater inside a glass tube, with which you can use this method, but you must carefully bend the hook on your copper wire to the diameter of the glass, being sure it puts no pressure on the glass.
This heater is responsible for melting all that frost that we don't have to deal with since the advent of Frost-free units, and it glows a dull red during the defrost cycle, so there's plenty of excess heat for our purpose.
Anyway, since copper's such a good conductor of heat, some of the defrost heater's energy will transfer down the copper wire, into the drain, and keep it open. What I like to call 'stupidly simple', this uses no extra electricity and works extremely well!
One precaution: hang this piece of copper *loosely* over the defrost heater. Don't squeeze or crimp it on, or you risk causing a "hot spot", damaging the heater.
Note: I get a lot of questions as to whether this wire will melt the rubber drain grommet or plastic drain tubing. I've installed literally hundreds of these wires (wish I'd kept count!) and have never seen any damage caused to those areas.
Keep in mind that when the unit switches into defrost, the inside of the freezer is at or below zero. Most defrost cycles last 20 minutes max, with the heater shutting down before the cycle
ends, so the warmth that travels down this little copper wire isn't nearly intense enough to melt anything but ice.
Hope this makes sense! Good luck
David
Posted on Dec 05, 2017
SOURCE:
  • 87 Answers
SOURCE: Whirlpool s/b/s refrigerator - water not evaporating on freezer side - collects & freezes under bottom food bin
Did any of the repairmen replace the heater which is at fault or did all three of them change it? If it has not been changed then I would suggest that it should be. If it continues to be a problem then you can get drainline heaters added to the system but you would need to talk to a fridge guy before they wasted a journey. The other possibility is that the front cover is not inside the drain pan or a leak in the drain pan, and if you have an icemaker you could even get water coming from further up the cabinet. Either way I would suggest picking your favourite of the three and tell them that the problem is unresolved. Most fridge guys offer some sort of warranty on work that they do. Hope this is of some help.
Posted on Sep 11, 2007
SOURCE: Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Posted on Jan 07, 2009
peyton32034
  • 410 Answers
SOURCE: Crosley Servidor WCR17/E K3 Top Shelf and Drain Plug Freezes Over
first thing I would suggest is to flush the drain line. defrost any ice in the drain and then flush warm water thru the line until it flows freelyif  your having a hard time getting the line flushed out you may try using a large syringe or turrkey baster filled with warm water to forcfully flush water thru the line. this will most likely fix the problem.
you didnt mention if food was freezing in the refrig as well as the drain but there may be an off chance that the temperature control could be bad. since this is a manual defrost unit it depends on above freezing temps to help keep frost off of the cooling coil. if the temp control goes bad it will allow sub-freezing temps and possible drain freeze ups. so if the drain continues to freeze you will need to replace the temperature control.
if it comes to that, the control actually has a part number on it since maytag cant find your model number.
message me back if you have any further questions. thx peyton
Posted on Jan 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Refrigerator freezer drains keeps freezing over, not plugged.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jul 02, 2009
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
Whirlpool top freezer refrigerator has water in bottom refrigerator
when the machine goes into defrost the heater in the freezer comes on and melts all frost off of the evaporator coil,the water goes down a drain line down to where the compressor and condensor coil is and there the water evaporates,your drain is blocked so the water can't drain down and leaks into the fridge section.when you write looking for answers you have to send the model number off of the machine,if the freezer is on top open the fridge door and look on the left side wall up near the ceiling and there should be a tag with model number,unplug the fridge or shut down the cold control,remove everything from the freezer and remove the back inside wall of the freezer,with a hair dryer melt out all the ice under the evap coil,i use a steamer to clean out the drain,if you don't have one you can try a turkey baster or anything that will push air or water down the drain hole,when you think the drain is clear pour hot water into the hole,if it drains down then it's clear,if not keep hitting it,you can also heat up the back center wall and ceiling in the fridge section to help melt out the ice.there's also a heater probe you can buy that you stick into the drain and it raps around the heater,when the heater comes on the probe heats up and keeps the drain from freezing up,you can also use a ground wire from an electrical piece of house wire or from a cable wire,cut a piece around 6 inches,stick it into the hole and rap the end around the heater,if it's a glass heater connect the wire to the metal in front of the heater,if 6 inches is to long trim it down a little so it fits.good luck,if you need anymore help let me know.
Jun 19, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into the refrigerator from the freezer it seems to be worse when the ice maker is on
if it's worse with the ice maker on i'd have to say the ice maker is leaking but normally the water is from a blocked drain in the freezer.unplug it,remove everything out of the freezer,pull off the inside back wall of the freezer,melt out all the ice with a hair dryer,next you'll see a hole under the evap coil,that's the drain,you have to free it up,i use a steemer to blow down through the drain but if you don't have a steemer keep heating up the area where the drain hole is,you can try using a turkey baster to blow through the drain,when you think the drain is clear pour hot water into the drain hole,if it goes down you're done,if it doesn't keep heating it until the water drains down the hole.also open the fridge door,in the top of the fridge in the middle of the ceiling and where it touches the back wall you'll see a mold,that's also the drain,heat that area up with the hair dryer to melt out the ice in the drain.the problem is slime builds up in the drain,when the fridge goes into defrost the heater comes on and melts the ice off of the evap coil and the water goes down the drain and into the drip pan on the bottom of the fridge,your drain is blocked and the water is leaking into the fridge,the drain has to be cleared.good luck with your machine.if i can help you with anything else let me know.
May 11, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is producing water which seems to drip down from the top rear center of refrigerator which is below the freezer. The amount is 1 or 2 cups per day and it collects below the bins at bottom of...
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The freezer floor of my refrigerator freezer (top freezer) has ice on it. There is some water in the refrigerator section.
First what you have to do is unplug it and leave door open over night, tto let the ice melt down. Then when you go back the next day, you need tto check if the defrost timer is working, if it is you need to check the heater and if thats ok you need to check the thermostat, One of these 3 things are gone.
Jan 20, 2010 | Kenmore 64192 / 64194 Top Freezer...
REFRIGERATOR LEAKING WATER INSIDE THERE IS NO
Remove the food and remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you
see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Nov 07, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a kitchenaide refrigerator model ktrp22embl01 that is leaking into the refrigerator? I put a towel on the top try. Could it be the freezer? How to check?
Remove the food and ice maker ( if equiped ) from freezer . Remove the screws holding the rear panel , and remove the panel . Using a hair dryer , start in the middle , below the coils , and defrost until you see the drain hole . Use hot water to help clear the hole . When water starts to flow down , use a piece of hose , inserted into the drain , and blow thru it , to remove any debris built up inside the drain line . I would also get a piece of solid ALUMINUM wire , about 9" long , completly stripped of insulation and insert it into the drain hole as far as possible , without any force . Wrap the other end about 1-2 turns , around the black rod ( defrost heater ) , just above the drain hole . When the refrig goes into defrost , the heat will transfer to the aluminum wire , keeping the drain from freezing up again due to ice .
Sep 13, 2009 | KitchenAid Refrigerators
Water is accumulating in the refrigerator
Remove the food from the freezer and icemaker (3 screws and a plug hold it in place ) . Remove the screws holding the back panel of the freezer in place , and remove the panel . Using a hair dryer , below the coils , start in the middle , and defrost until you see the drain hole . Keep defrosting the hole , until water starts to drain thru . Use a small piece of hose inserted into the drain , and blow thru it , to clear out any debris accumulated in the drain line . Hot water helps to clear the ice from inside the hole also . To make this a permanent " fix " , get a piece of aluminum solid wire ( 14-16 guage , like an appliance ground wire ) about 8 " long . After the drain is clear , where water runs thru , insert 1 end into the hole as far as it will go without any force , bending slightly if necessary . Wrap the other end around the black tube ( defrost heater )above the hole about 1 - 1 1/2 turns . Whenever the fridge goes into defrost , the heat will transfer to the wire , therfore , keeping ice from blocking the drain again .
Sep 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Looking for help with the Whirlpool GR2SHK-XKQ00, top mount refrigerator. Water is coming into the refrigerator from the freezer, possibly linked to self-defrost cycle, def. not ice maker. Drain pan is...
Remove the lower freezer panel end then remove the rear panel . Remove the ice under bottom panel . Useing a hair dryer , heat the aluminum tray under the coils until you see the black drain hole . Continue defrosting the hole until free of ice . Could help useing a small screwdriver into hole . Even hot water into hole could help to clear . Once water will drain into hole , use a small hose inserted into hole and blow thru it to clear and obstruction in the line (line is inside the cabinet , unaccessable ) , Then find about a 14-16 gauge aluminum wire , aluminum fence post tie , aluminum ground wire , and insert it into the hole until resistence is felt . Wrap the top portion about 1 turn around the calrod (black) heating element and cut off the rest of the aluminum wire . The element will transfer heat to the wire during defrost , to keep the drain hole clear of ice .
Jul 22, 2009 | Refrigerators
Ice is forming in the bottom of my freezer, blocking the drain hole, and dripping water into the refrigerator. We defrosted it, and it worked fine for 2 weeks. Now it's doing it again. The drain hole is...
Defrost the drain again and use an aluminum wire , maybe 14-16 guage ,inserted into the drain hole approx 4 inches and wrap about 1 turn of the top end of the wire around the calrod defrost heater , This wire , will transfer heat from the heater to the drain hole , keeping it from freezing up again . Also , once cleared , use a small hose and blow into the drain to remove any debris possibly accumulated . Do this before installing the wire .
Jul 20, 2009 | Refrigerators
Refrigerators Logo
293 people viewed this question
Top Summit Refrigerators Experts
Lawrence Oravetz
ray gallant
ray gallant
Tom Chichester
Are you a Summit Refrigerator Expert? Answer questions, earn points and help others
