Hi Moshe.
you have not said what model of camera.
but try this.
Copy any desired files from your camera's SD card to your computer. Ensure that the SD card is installed in the camera, then press the rear Menu button to wake thecamera. Press the rear Menu button repeatedly until "DELETE FILES" appears, press the top Shutter button to select.
How to Delete Files from microSD Cards - GoPro
https://gopro.com/.../How-to-Delete-Files-from-microSD-Cards-with-HERO3-HERO4
or go to this link and read up some more.
How to delete pictures from the camera memory Google Search
SOURCE: transfering pictures from my memory card
when you connect your camera to the PC.
look in My computer and find the drive ( camera ) probably shows as Drive F:/ G:/ H:/ I:/ or similar.
Right click and open, then copy to folder on desktop, named My-Pictures ( Or similar ) once you,ve copied your photos from memory card to desktop on PC. Format the memory-card. which will erase all data. ( Right Click Format )
This should solve your problem.
Mike @ compurepair.
SOURCE: i deleted pictures i want back
Once u have deleted the pictures from the
memory card u can't get it back.
thanks..
SOURCE: can't delete pictures?
I would reset your camera to the factory settings to fix your settings being locked.
You can find that information on page 130 of your manual.
You can find your manual here
http://exilim.casio.com/current_owners/manuals
If you can't delete pictures on your camera or your card, you need to make sure Protect is not set to on. You can find that on page 90 of your manual.
Thanks for coming to FixYa, and don't forget to rate my solution.
Rob
SOURCE: how do i delete all pictures from memory card for
Look for "format memory card" in the setup options menu on the camera.
