I cant start my taxi.pressing key fob and nothing happening.trying to put my 4 digit number in and nothing happening
SOURCE: renault megane key fob wont work
I had the same problem with mine
your key fob is now out of sync with the ECU to sync them just follow this link (renault will charge up to £180 for new key and to sync it)
http://renaulthelp.110mb.com/ImmBypass.html
SOURCE: the battery in my VW key fob is dead, now I cant start the engine
No. VW has made it nearly impossible to solve any key-related problems without a costly visit to the dealership. Battery must be replaced, and I assure you. the dealership will advise you that the ONLY place that you can find that particular battery is from the dealership. They like it that way.
SOURCE: Immobiliser problem - 94' Golf Mk3 GTI 2lt 8 valve
just unplug the immobiliser unit. its behind the glove compartment for rhd models.
SOURCE: MY VOYAGER IMMOBILISER SEEMS TO HAVE KICKED IN
Its likely to be the 21 pin plug behind the heater control panel. Remove the long plastic strip under the control panel (prise of gently, held on by 2 clips) remove 2 screws behind this and 2 screws above on panel. The whole lot should easily come away. There will be 3 plugs, remove all three and try to start the car. If it starts your problem would be the earth. Hope it helps.
SOURCE: Key fob has stopped working wont turn off alam,immobiliser.
lock the car with the key and hold opver for 30 secs then press/hold unlock button on key fob for 30 secs,should reset....
If your key fob has just stopped working try this:
If the above fails try this:
