Hi
Thanks for using FixYa. Error F11 means it is a serial communication error between the Central Control Unit (CCU) and the Motor Control Unit (MCU) and the communication cannot be sent correctly to these units and the washer. To resolve the issue you are facing with, please check the wire harness connectors to the MCU, then the motor and Central Control Unit (CCU). Also please check the drive system for any worn or failed components, MCU, CCU, motor and wire harness.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Sorry to be the bearer of bad news.
F11 indicates a fault with the main control board.
