Watches Logo
J
John Helmerson Posted on Nov 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Rolex GMT Master works perfectly while I am wearing it but when I leave it on the night stand each night it usualy runs down and stops working after five or seven hours.
Level 3:
  • Rolex Master 18,429 Answers
  • Posted on Nov 08, 2017
Rolex Master
Level 3:
Answers
18429
Questions
Helped
1403809
Points
62248
This watch will keep great time if it has been wound via crown.
5 Related Answers
A
Anonymous
  • Posted on Feb 23, 2008
SOURCE: Rolex runs down
Unfortunately, it actually may be true that the watch is functioning properly.
A self-winding watch that keeps running down can be an early symptom of Parkinson's disease.
Read item 4 "Frozen in Time", at this link, for details:
http://www.dls.ym.edu.tw/neuroscience/news41.html
Anonymous
  • 100 Answers
  • Posted on Nov 17, 2008
SOURCE: Rolex watch stops only when I wear it
Kristy,
Stress won't affect your watch's timekeeping ability, but position will. When you lay the watch down at night, in which position is it? Also, during the day, is your arm in a static position for long periods of time? A Rolex chronometer (like the Datejust) should run approx. 36 hours after being fully wound -- without any movement. If the watch stops dead, then there is a problem with the movement and/or rotor. If it losses time, I'd bet on a static position problem. Let me know the answers to those questions and I'll try to help you get to the bottom of the problem.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 17, 2008
SOURCE: i want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Anonymous
  • 26 Answers
  • Posted on Jan 06, 2009
SOURCE: Rolex GMT Master II date changing after midnight
If it still under warranty take it back to rolex, other wise take it to an indpendent watchmaker they should be able to fix it for a small fee. The watch probably doesnt need a service yet if it is new.
Anonymous
  • 7 Answers
  • Posted on Jul 05, 2009
SOURCE: how to change time and date in Rolex GMT + Master
Hi rajbhaduri. There's a complete guide to mastering these amazing watches at http://www.koniaris.com/rolex/
Enjoy! Cheers; Eagle58
My rolex works good on the table, but stops every now and then when i am wearing it
That's not good, obviously. Who serviced it?
How long ago? Do you have a receipt with warranty of service?
Generally, Rolex's run forever without much service. If an authorized Rolex technician worked on your watch, it would be running like a .... Like a Rolex! Kidding aside, get in touch with the services, nukes you were simply told that by the seller.
tip
ROLEX GMT-MASTER II USER GUIDE.
Follow this link and download user guide for ROLEX GMT-MASTER II watch: http://www.rolex.com/en#/Download/
on Mar 15, 2010 • Watches
Water
You would have to unscrew the back (needs a special tool) and leave it open to dry..then probably have it cleaned. Only a professional watch mender can do this.
BUT Rolex watches are water resistant. It either isnt as Rolex, or you went too deep
I have a 1992 Rolex DAteJust- it runs great for several weeks .. of everyday use, and then it will stop for no apparent reason. After I shake it a few times.. it runs again.. but it seems that it...
Nail on the head. Take it to a good repair/service shop that does Rolex service. Know this, it wont be cheap. But you will get the watch back in great condition and it will run perfect.
10helpful
My rolex datejust watch has stopped working...rolex watches don't operate on batteries right? Why has it stopped ticking?
mcdevito75 here, The answer is no, Rolex watches do not operate with a battery. Most Rolex watches are Automatic winding with the motion of your wrist / arm. Of course if you leave your Rolex on the dresser for say 30 hours, it will run down, simply hold the watch in your hand and with a gentle rocking motion say from 6--to 12 O'Clock for about 30 seconds, this will give your automatic Rolex an initial wind up, from there you just wear the watch and it will continealy wind itself. You may also have the non automatic Rolex in which case you would have to wind it dailey. If your Rolex will not run at all no matter what you try, Check out the repair service directory here at fixya, bottom of the page click on repair service directory then watches.
Aug 01, 2010 • Watches
How do i set the the 24 hour hand in a rolex 16758
Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
3helpful
When i change the 2nd time zone hand of my rolex gmt master II it makes my minute hand wobbles is this normal?
This happens due to friction between the wheels and cannon pinion in watch movement, especially if your Rolex has not been serviced for a few years, however, it should not affect timekeeping. I'd advise to show your watch to the watchmaker and clarify exact cause of this.
Rate me, plz.
How to change time and date in Rolex GMT + Master watch?
1helpful
Kristy,
Nov 06, 2008 • Watches
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
