This problem can be solved by cleaning the screen properly. If the cleaning doesn't work there might be a connection problem. For that, you have to reassemble the screen of your Keurig machine. Read this article for a complete fixing guide
I had the same thing with Ninja CE251 (these one https://www.bestadvisor.com/best-coffee-machines ) and it caused by dirt/coffee residue, getting under the bezel around the screen, as Jav Javman wrote. It need to clean twice a month\two month and all will be ok
The problem with the touchscreen not responding, is caused by dirt/coffee residue, getting under the bezel around the screen. Sometimes a tissue soaked in Windex, then polished with a dry one , will temporarily remedy this. The only permanent fix is to disassemble the head, remove the lcd screen and clean it thoroughly, as well as under the bezel.
SOURCE: Garmin Street pilot 2720 touch screen not work.
Did you ever get your touch screen to work mine stopped working also i have the 2720.
SOURCE: Keurig B66 model - "Not Ready" message when I push
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101-=-=-
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
