Wa13v5
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
SOURCE: i need a manual for WA13UP Top load(samsung) washing machine
water running out at the draining pipe the while the machine fill itself with water
SOURCE: dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
SOURCE: i want users manual for
You can get them at;
www.devicemanuals.com/guide/Washing20%Machine/samsung-manuals.html
or www.samsung.com/support
