Refrigerators Logo
Frank Cafaro Posted on Oct 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
NOEL
Level 3:
Top Expert:
  • Refrigerators Master 8,606 Answers
  • Posted on Oct 23, 2017
NOEL
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322253
Points
68630
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
4 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 06, 2008
SOURCE: frigidaire freezing in refrigerator
the damper door could be frozen in open position, supposed to open/close to regulate refig temp. if left open all food will freeze
Anonymous
  • 6 Answers
  • Posted on Dec 20, 2008
SOURCE: Coil is freezing on freezer
Yes, the seal will let outside air into the unit causing the coil to ice up. When it ices up the air cannot blow through the fins in the coil, thus no cold air goes to the refrigerator section.
richard switzer
  • 20 Answers
  • Posted on Apr 23, 2010
SOURCE: Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
bobicehouse
Robert Moller
  • 1524 Answers
  • Posted on May 21, 2010
SOURCE: why does my refrigerator freeze everything?
Change the thermostat
Samsung rb2055sl. Refrigerator temperature is fine but freezer isn't
Possibly requires re gassing with coolant. Call a refrigeration engineer.
Freezing
Keep the prep top table pans covered when not in use. Never leave empty holes where pans should be. If the pans are empty put a couple of inches of water in them to keep some heat load there. Check the door gaskets and door seal on the base doors. Make sure the thermostat is set on number 5. If all of this checks out probably need a new thermostat, but if it's erratic I suspect you will find it's one of the former problems.
2helpful
2answers
Past couple days the refrigerator side is freezing everything. turned the setting all the way back and still freezing......dont know if there is a thermostat and if its a DIY fix
Damper door is either broken, stuck open or stuck open and frozen with ice. Damper door is located in the top left corner of the "refrigerator side" of the fridge. Damper door may be concealed by an outer plastic covering usually held in place by a 1/4 inch screw.
Thanks and let me know if that helps,
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie GOFAR Services, LLC
Refrigerator is freezing everything and the freezer compartment is covered with ice. I tried changing temperatures but they go back to -12 for freezer and 36 for fridge. Any suggestions?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Hi, My Bosch Model B20CS50 SNI/01 side by side
It sounds like the fridge is in need of a regas, but that seems unlikely after only three years, although not impossible. An indication of that would be if the compressor could be heard to be running all the time. If it cuts out after running only a short time it could be the thermostat that has gone faulty.
I have a bottom freezer model that also freezes on top! I've cleaned the coils underneath (and it was pretty bad), and that seemed to work for about a week, but now the unit seems to run alot even though...
cleaning the coils is always a good idea, that's how the unit disipates the heat it pumps from the inside of the box. clean coils make it work more efficiently. Frosty suggests a door gasket leak, allowing fresh, moisture ladden air in, that turns to frost. Runs all the time- check door gaskets. they are replaceable. Could also be a bad thermostat. thermostat is running the fridge, trying to reach the set temperature but won't shut off when it reaches it. Unplug the fridge or shut off the breaker is easier. (good wiring practice mandates a dedicated circuit for refrigerators). change the thermostat.
Does the model cool by allowing cold air from the freezer into the refrigerator or does it have separate cooling equipment like some sub zero's? Is there something blocking air flow from the freezer to the refrigerator?
spencer
I'm having trouble with Maytag model MF12067AEB refrigerator that started about 6 months ago. The vegetables/fruits are freezing in the bins....the repairman has been to my house 3 times....replacing the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
1helpful
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
