C
Charles Onyekachi Posted on Oct 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sharp 5618 is showing H5 error code, how do clear it?
George Mclaughlin
Level 2:
Sergeant:
  • Sharp Expert 372 Answers
  • Posted on Jan 09, 2018
George Mclaughlin
Sharp Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128146
Points
839
You have had multiple paper jams in the fuser. clear the jams and reset the code
5 Related Answers
Anonymous
  • 71 Answers
  • Posted on Feb 25, 2008
SOURCE: sharp AR 250 with error code H5-01
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Anonymous
  • 2072 Answers
  • Posted on Mar 17, 2008
SOURCE: Sharp AR-287 Copier error code H5-01
Anonymous
  • 148 Answers
  • Posted on Jul 02, 2008
SOURCE: Service Mode On Sharp SF2530
A little rusty on this machine, but try this.
This code means you have had to many paper jams in the fuser without removal. Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
Hope that helps...
Lbcoaster
Anonymous
  • Posted on Dec 11, 2008
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Anonymous
  • 87 Answers
  • Posted on May 09, 2009
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
1helpful
3answers
How to reset sharp AR -5618
how to reset the toner chip as it is costaly
2helpful
2answers
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
5helpful
Error code H5-01
HI.H5-01
check its cable
reset this code
press ,p,*,clear,*
4helpful
2answers
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
11helpful
2answers
Sharp AR 250 with error code H5-01
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
