Optics Logo
s
sheila jackson Posted on Oct 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I put the co2 in my f4 air rifle - The Optics
  • Anonymous Oct 23, 2017
    Don't you read the responses to your queries at all ? And should a little girl be playing with guns anyway ?
james laughton
Level 3:
  • The Master 2,195 Answers
  • Posted on Oct 20, 2017
james laughton
The Master
Level 3:
Answers
2195
Questions
Helped
411300
Points
6636
Not a co2 air rifle break barrel air charged nitro piston
3 Related Answers
johnz1313
  • 88 Answers
  • Posted on Aug 29, 2009
SOURCE: co2 leaks from chamber on crossman modle400 rifle how do i fix it
Check thare is a rubber o ring missing or broken in the air chamber
Anonymous
  • 2702 Answers
  • Posted on Nov 28, 2010
SOURCE: my rifle leaks air when i screw in the co2
yes you can buy the srevice kit with all the "O" rings you need to service it from crosman
Anonymous
  • 53 Answers
  • Posted on Aug 10, 2011
SOURCE: @centurylink.net I have a CO2
i am almost 100 percent sure that it is just a seal, CO2 is bad for drying out seals. Replace the seal and see if that fixes the problem, and if it does, go get some oil for firearms and put it on the seal before every 3 CO2 canisters.
Daisy .177 calibre BB rifle will pump but not hold air.
Question edited for clarity.
Question moved to a Daisy category. Please always include the model.
You need a set of o-rings and seals for it. Try Pyramid Air.
Pyramyd Air ' Premier Online Airgun Store
Pyramyd Air https://www.pyramydair.com Check out these great deals on air guns, airsoft, pellet and bb guns and accessories. This is your one stop shop air gun mall. Get yours today!
Air Rifles
PCP Air Rifles - Spring Piston Rifles - Gas Nitro Piston Rifles
Air Pistols
CO2 Pistols - PCP Pistols - Spring Piston Pistols - Gas Piston Pistols
PCP Air Rifles
Umarex Gauntlet - AirForce Talon SS - Hatsan Flash QE - ...
Air Rifle Accessories
PCP Accessories - Air Rifle Silencers - Parts - Stocks & grips
I have a F4 crosman air rifle and I can't find the place where the co2 goes I need help
It is a break barrel air rifle that when it is cocked the piston is pushed back drawing air into the cylinder so that when the barrel is closed the breach seal covers the transfer port squeeze the trigger piston flies forward forcing the air through the transfer port into the barrel accelerating the pellet up the barrel and towards the point of impact
It is not a co2 powered air weapon
@centurylink.net I have a CO2 300 air rifle that I have for many, many years. When I put a CO2 carridge in it the air escapes before I can shot more that a couple BB's. I don't know if the air...
Aug 10, 2011 • Daisy Toys
1helpful
I have a daisy powerline 990 air rifle, I need to know how to repair this gun. It will no longer pump up air or hold pressure.
You might have a bad O ring. I keep hearing a leak out of 990 and i think its from the coldness of the Co2. Every time i put Co2 in it it gets worse.
Apr 23, 2011 • Daisy Toys
2helpful
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
1helpful
I have a crOsman model 1077 that wont take a CO2
Probably not by you, but by the shop, maybe. It sounds like the needle was bent and lost it's seal. Crosman has repair stations, if they don't fix it, they will send you another one. I have sent them guns before and got brand new ones instead of the old piece of junk I sent them for repair. They also bought out Sheridan/ Benjamin line of Air rifles, And they repair all those too. I sent them an ancient rifle, an old Benjamin Franklin,17 cal. bare bones stock and barrel only, they sent me back a total refurbish, welded, painted, new .22 cal.barrel, all new guts, unbelievable. I think the total cost was $35 on that one. They wanted $15 for paint, I told them I didn't want it painted, they said, OK, Get a hold of them. Hope this helps.
3helpful
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
6helpful
2answers
Co2 leaks from chamber on crossman modle400 rifle how do i fix it
Top The Optics Experts
NOEL
NOEL
vince
Are you a The Optic Expert? Answer questions, earn points and help others
