SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of
the 220V. Immediately the malfunction code (error code) of "C05"
appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found
the "Trouble Reset Switch" (not shown in the user manual) by opening
the upper back panel and pressing the small black button in the lower
right hand corner of the middle circuit board (green).
It worked perfectly!
SOURCE: How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
I need to know m/c model
SOURCE: need to reset the fuser counter
Hi there.
Download Service Manual here: http://nodevice.com/manual/Konica_Minolta_QMS_magicolor_7300_Service_Manualpdf/get690.html
and follow the instructions.
Regards.
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
most konica minolta 0500 codes is fuser related and a tech has to reset it
