SOURCE: kenmore washer lid switch bypass failure.
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
I hope this helps you.
Please let me know if I can assist you further.
Thanks
Vic
SOURCE: kenmore top loading washer locking lid switch bypass
Yes. Snip the wires at both sides of the switch. Then fuse the wires together with electrical tape. But before you do that...you state it's a 2011 model? It should still be under warranty.
Locate the switch by the lid and simply connect a wire between the two wires going to it to affect a bypass.
