Is your TV a Samsung?
..if not, disregard this...
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
Samsung power defect causes some TVs to fail and class action suit follows
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
SOURCE: have picture lose picture tv turns off and on
the lamp has a life cicle. if yours is been used a lot. then the lamp has to be changed. when the tv cannot turn on steady and gets off imm. the computer inside the tv tries to turn off the set but the lamp charges again and the micro tends to keep working. the first step to take in this tv is to change the lamp to eliminate this common source of problems
SOURCE: A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
SOURCE: at start up, tv comes on, sound and picture. A few
Your Lamp needs to be replaced.
Mats Electronics 1-800-628-1118 they have Lamps for $89.95
