SOURCE: Username and password
You will probably need to reset your router to get access to it again with a known username and password. BEWARE THIS WILL PROBABLY RESET ALL CONFIGURATION INFORMATION AND YOU WILL BE REQUIRED TO COMPLETELY RECONFIGURE YOUR ROUTER INCLUDING POSSIBLY ISP SPECIFIC INFORMATION. If you cannot do this including knowledge of all the required answers and proceed anyway you may lose access to your internet connection until this is successfully done. Proceed beyond this point AT YOUR OWN RISK.
Follow the link below to determine the model of your router
Router Link
As your profile indicates you are from Australia -- there is a link at the top of the page for a DI-624+ that may also apply to you.
If this does not work or your model is not a DI-624 as indicated try the following Assuming you have a DLINK router
Go to www.dlink.com
Choose your country
Choose Support
attempt to access product information -- if your model does not appear there may be legacy products link on the page to choose
Download your user guide.
The following link may provide an emulator for your router to allow you to preview the configuration process (this does not configure your router. You may have noticed this emulators link earlier when accessing product information above, if you could not use the link.
Emulators Link
AGAIN PROCEEDING BEYOND HERE CAN RESULT IN THE LOSS OF ACCESS TO YOUR INTERNET SERVICE -- proceed with care.
Doing this will may require you to configure specific ISP required
entries into your router to restore internet access, I do not know what
those requirements are now. I may be able to research them if you
provide information about your internet service provider such as their
web site or help/support web site. Be aware that you will require all answers for this before doing it as you may not have internet access again after starting this until you successfully complete this. With all the previous warnings in mind you can consider the following step.
Using the instructions in the user guide you can probably reset your router and get access to the configuration.
SOURCE: I forgot the router's username and password.
Try admin, admin. If that doesn't work press the reset button and it will restore the factory settings. You will have to reconfigure the router.
SOURCE: I can't log into my account when i KNOW my
open a notepad and enter the same user name and password there just to check if the num lock or capslock are on or there is some other issue with the key board
hope this helps
cheers,
pls rate it
SOURCE: I forgot the username and password and can't log
Reboot router.Power off for a min.find reset button, hold in with a paper clip or pentip for a min, power up router.
username=admin
password=admin or password
SOURCE: I forgot Admin Username and Password
When I forgot Dell Windows 8 administrator password, I got Windows Password Recovery Tool Ultimate to support me make a password reset disk with USB and reset password efficiently!
Forgot your username? If you've forgotten
your username, and you're logged in on your device, you can follow these
instructions to find it: 1. Click the
"gears" icon to go to the Options menu. 2. Tap the
"Account Info" section where you see your Textfree number 3. Your Username is the name just before the
@textfree.us.
Enter username in Login screen and click the link "I
forgot my password". So password will be sent to email id to followup for
login.
Sincerely, Thiyaga
