Printer control board (PRCB) or Paper feed motor (M41) is bad hope its the motor board will be expensive!!!!!!! check behind the draws paper stuck!!!!! also pull out each draw find if thats the problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
SOURCE: Konica Minolta C6500 Error Message
There is a paper somewhere in the copier. Maybe earlier you have a paper jam and one paper or just a part of the paper is still in the copier.
Most likely the paper is near the imaging unit.
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
SOURCE: konica minolta bizhub pro c6500 error c2452
i have checked all those parts and tested them with a multimeter and there seems to be no problem is there any other way i can overcome this problem
