Possible power board failure
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty. 35 times flash can be considered as continuous.
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at [email protected] if you run into difficulties.
-Dave
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
