SOURCE: 96, polaris 600 xlt # 3 no fire
The problem was contaminated pump/fuel. Disassembled carbs and pump, inspected and cleaned, engine runs like new. Thank you
SOURCE: head light and tail dims when idleing and driving
Lighting coil is bad. Take off flywheel and replace the lighting coil. Should solve your problem.
SOURCE: my 1995 polaris xlt 600
COULD BE THE THROTTLE SAFETY SWITCH OR THE STATOR. CHECK TO SEE IF IT HAS SPARK AT OPEN THROTTLE, IF SO IT IS THE THROTTLE SAFETY SWITCH. THEN IF U PICK UP A MANUAL IT WILL WALK YOU THROUTH THE TESTS FOR ALL THE OTHER CONPONENTS.
THERE ARE MANY THINGS THAT CAN CAUSE NO SPARK.
SOURCE: I have a 98 polaris
THIS ENGINE IS A PORT ENGINE, ANY TWO STROKE OIL WILL WORK. HOWEVER EVERYBODY HAS DIIFERENT OPINIONS ABOUT WICH OIL TO USE
