Televison & Video Logo
Alan Marchman Posted on Sep 17, 2017
LG 32ls3410-ub Television has sound but no picture. Need opinion on what to replace first.
The picture went out on our LG 32ls3410-ub LED TV. It still had sound, and if I shine a flashlight onto the screen I can faintly see the menus and can cycle through them. I've inspected the visible boards, but didn't not see any apparent damage to any of them. If anyone has dealt with this before, what should I consider replacing first, the T-Con board or the LED driver board?
Eric Fay
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 17, 2017
Eric Fay
Contributor
Level 1:
Answers
Questions
0
Helped
806
Points
5
  • Lesego Lekhoathi
    Lesego Lekhoathi Jan 10, 2018
    so what do i need to do?
2 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Feb 05, 2015
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
gopakumarg43
  • 76851 Answers
  • Posted on Feb 10, 2017
SOURCE: 2nd try see last sentences....lg led 32ln5310 tv, sound but no picture, no backlights, nothing visible on flashlight test, what should I replace? Main board, T-Con Board, Power Supply board or Leds
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
2answers
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
1helpful
My LG 55LV5400 Tv went of and will not come back on?How to fix this problem
LG 55LV5400-UB has a well known problem with the main board resulting in the symptom you describe or in loss of HDMI inputs or loss of sound.
it has to do with the main processor and some people recommend baking in an oven to help cure it.
We do not. There are many reasons why this is wrong, but the truth is it *could* give a short term success; it is almost certain to lead to long term problem and we have pictures and videos of boards sent to us after such attempts - usually already warped beyond repair.
Simply put, I'd say there is 99% chance you need your main board serviced or replaced.
here are two links to help with each option:
Repair:
http://www.coppelltvrepair.com/p/1632/ebt61521404-61521404-main-board-repair-service-from-lg-55lv5400-ubausylhr-led-tv
Replacement:
http://www.coppelltvrepair.com/p/1634/lg-55lv5400-ub-main-board-ebt61521404-61521404-serviced-tested-50-credit-for-old-dud
2answers
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 • LG 47LS4500
How do I get the picture back on my LG LED 50 flat screen? Sound works, no picture.
-You have a bad panel. Led arrays internal to the panel are defective. Replacement cost exceeds economical repair.
3answers
No picture, only sound on LG 47LV5500: how do I get picture back?
Definitely odd for sound to come through and not sound, especially via an HDMI connection.
I would contact LG for support, your TV could be defective.
Good luck
2answers
My lg LCD tv has sound but no picture
You need a new picture tube. They cost about 175.00 and up.
4helpful
Replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
