If it is a F18 error,t means that the pump out time is too long. Most likely clogged filter.
Open panel on the bottom right, drain the water out using the left hose and remove the filter plug. Have a look and clear obstructions.
That should help.
Find out the significance of the code and then attack the issue. If parts needed go here. Search Over 2 1 Million Appliance Parts
SOURCE: my bosch logixx8 washing machine
Open the service flap, bottom right corner, and clean the pump.
That should do the trick
SOURCE: I would like to download
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
