Washing Machines Logo
Carrie Hill Posted on Sep 10, 2017
Where is the location for fabric conditioner on Super General Top Load Washing Machine, Model #: SGW620?
5 Related Answers
gittos73
peter gittos
  • 247 Answers
  • Posted on Nov 17, 2008
SOURCE: The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
Anonymous
  • 71 Answers
  • Posted on Dec 15, 2008
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Anonymous
  • Posted on Dec 26, 2009
SOURCE: Instruction manual for Whirlpool Heavy Duty Series 8 Machine
I have the manual if you need help, but the mechine is simple to use, just put the fabric conditioner in the top of the thing in the middle (inside the machine) the bleach dispenser is is just for bleach. You just get a cup of washing poweder and throw it in!
Anonymous
  • Posted on Jan 09, 2010
SOURCE: remove and replace fabric softener dispenser on kenmore model 20952992
I just did it. All you do is pull up on the blue part -- put the fingers of both hands under the rim and pull. It isn't screwed or bolted on. If there's a lot of gunk built up, it's all the harder to pull up. Be prepared for some yucky stuff. It would be nice if that whole section would come out, since you have to clean the area below with Q-tips.
Anonymous
  • 51 Answers
  • Posted on Feb 03, 2010
SOURCE: My washing machine isnt accepting fabric conditioner
have you lifted up the conditioner flap on the drawer, you would of seen a long plastic tube sticking up, this tube gets blocked from time to time resulting in the softner not going into the machine. if you have cleaned this tube when you took the drawer out, then the only other cause is the solonoid vavle is the fault. this is easily replaced.
if you have any difficulties, you may if you wish, email me at [email protected]
pallesappliancerepairs.com
My super general top load automatic washing machine model sgw720n water level won't stop and over flow!
If the water level in your Super General SGW720N top load automatic washing machine is not stopping and is overflowing, there could be a few possible causes. Here are a few steps you can try to troubleshoot and fix the problem:
  1. Check the water supply hoses: Make sure the water supply hoses are properly connected and there are no visible signs of damage or leaks.
  2. Check the water level sensor: The water level sensor is responsible for controlling the water level in the machine. If it is not functioning correctly, it could cause the water level to continue rising. You may need to have the sensor cleaned or replaced by a professional.
  3. Check the water inlet valve: The water inlet valve controls the flow of water into the machine. If it is not functioning properly, it could cause the water level to continue rising. You may need to have the valve cleaned or replaced by a professional.
  4. Check the control board: If the problem is not with the water supply hoses, water level sensor, or water inlet valve, it is possible that there is an issue with the control board. You may need to have the control board inspected or replaced by a professional.
If you are unable to resolve the problem on your own, it is recommended to contact a qualified service technician or the manufacturer for further assistance. It is important to follow the manufacturer's instructions when attempting to repair or troubleshoot your washing machine to avoid causing further damage or injury.
I have super general sgw620 washing machine,my drain area is upper and on the wall. can u pls advise how to use this machine with upper drainage system
The drain on the wall is called a Stand Pipe. It is designed to be higher than the washing machine so that you do not flood the building every time you do a load of wash. The Machine has a built-in pump to pump the water out of the machine when needed.
You will need to attach a washing machine drain hose to the machine. You should be able to find one at Lowes or Home Depot. https://www.lowes.com/pd/bosch-drain-hose-extension-kit-gray/1000024537?cm_mmc=shp-_-c-_-prd-_-app-_-google-_-pla-_-186-_-sosaccessories-_-1000024537-_-0&kpid&k_clickID=go_625713068_34614756550_111134534590_pla-261169297148_c_9027729&gclid=EAIaIQobChMIwc_2u8_-4AIV9x6tBh1fSA3fEAQYAyABEgJjjPD_BwE
2answers
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Super general SGW7100 E1
my washing machine super general sgw7100 has error E-62! how i solve this problem?
2answers
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Servis M6755W w/m - fabric conditioner drawer not emptying
I would take the top off and locate the operating lever for the fabric valve as it sometimes gets stuck with soap goo
eric
1helpful
2answers
Won't take fabric conditioner on final rinse
remove the top cover by removing the two screws at the top back portion of the unit.
slide back the top cover.
inspect the location of the soap and fabric conditioner dispenser. if it has three solenoids or two solenoids, maybe one of the solenoid is malfunctioning that is why it is not dispensing the fabric conditioner.
if it is a cable type, inspect the cable as it runs to the mechanical timer.
make sure that the cable is not broke and it is strecht as it should be.
check the mechanical timer if the cable holder is in place in the mechanical switch.
i hope i was able to help and solve ur problem,
tnx 4 using fixya,
drcool
2answers
Washing machine drawer
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
