Sewing Machines Logo
A
Anne Marty Posted on Aug 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change a needle threader on a Brother Innov-is 1500D
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 12, 2019
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814594
Points
14613
The needle threader cannot be used with the wing needle or the twin needle.
  1. Turn on the sewing machine.
  2. Raise the presser foot using the presser foot lever. ...
  3. Press (needle position button) once or twice to raise the needle. ...
  4. As shown, press down on the spool pin lever with your finger. ...
  5. Remove the spool cap.
5 Related Answers
Anonymous
  • Posted on Jan 25, 2008
SOURCE: Brother SE 270D Cassette threader
I too have a christmas gift causing headaches - loopy embroidery. But at least this one I found a work around for... I thread the cassette according to the arrows but when I get to "6" I loop up around the left side and over the top of the bend but DON'T go far enough to cut the thread. I leave about 4 or 5 inches loose and hold the end at the top-right of the thread cassette at about the 2 o'clock position. I push the cassette down into the machine normally and right about when the 6 is below the window the thread will cut leaving you holding the left over piece. Continue pushing down until click and needle will thread. Have not had any threading problems since learning to leave a tail on the thread. Hope this helps.
Anonymous
  • 8 Answers
  • Posted on Nov 12, 2008
SOURCE: the needle threader has stopped working
Check you needle size. On my machine the needle threader does not work with the smaller needles, 9/65 and 11/75. The eye of the needle appears to be just short of the hook on the needle threader. I have no problems threading needles in larger sizes.
Good luck,
SewReady
Anonymous
  • 34 Answers
  • Posted on Jan 31, 2009
SOURCE: automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Anonymous
  • 34 Answers
  • Posted on Feb 05, 2009
SOURCE: Broken needle threader?
Hi - welcome to FixYa. I have this machine, and unfortunately, the cassettes can break. If the threader worked when you first got your machine, I would suggest buying a new cassette (even if your threader is working). A second cassette is very handy because you can thread your next color in the extra cassette before the machine stops for the next color change - when the machine does stop, just put in the second cassette, and thread the other with the next color - speeds things up alot. And, if one of the cassettes does break, you aren't sitting in a puddle waiting for a new one.. You can find the thread cassettes for sale on a variety of sites - this is where I buy mine:
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Store_id=492&page_id=17
Some of the 270Ds came with a spool pin - look in your manual for a picture and for the instructions for installing and using the spool pin. You can use it for spool of thread that are too large for the cassette and I think you can leave it installed on your machine all the time. If you don't have your manual, leave a comment and I'll look mine and check the instructions.
Hope this helps. If you have a minute, a rating (good or bad) tells me if the information or solution I provide is helpful to anyone who visits FixYa.
If you would like me to write a tip on salvaging an embroidery project that has been pulled into a birdsnest, leave a quick comment and I'll add the tip. Thanks everybody, and good luck. Please feel free to comment if you need more help or have more questions.
Anonymous
  • 1116 Answers
  • Posted on May 01, 2010
SOURCE: AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
Brother sq8195 How do you thread the self threader.
Hi Ann-
I found this link for Brother SQ9185 regarding threading the self threader.
https://help.brother-usa.com/app/answers/list/st/5/kw/thread%20self%20threader/p/6518/page/1
How to use the automatic needle threader
Follow these steps to use the needle threader: 1. Thread the machine up to the needle. CAUTION The needle threader can only be used with home sewing machine needles size 75/11- 100/16. Check...
Hope this helps.
I also found this youtube video on threading a self threading machine. Highlight the link, right-click and "Go to https://video.search.yahoo.com/..."
https://video.search.yahoo.com/search/video;_ylt=AwrDQymj7u9dlzEABwz7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZAMuMWZiTVRFd0xqRXlpaEVKWGFfVmpnQS5NVGd4TGdBQUFBQlRGZ1cxBGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA1N0MlFsVHlFU1RPYm1nQVFkWFJrWUEEbl9yc2x0AzYwBG5fc3VnZwMxMARvcmlnaW4DdmlkZW8uc2VhcmNoLnlhaG9vLmNvbQRwb3MDNQRwcXN0cgNicm90aGVyJTIwc3ElMjBzZXdpbmclMjBtYWNoaW5lBHBxc3RybAMyNQRxc3RybAM2NQRxdWVyeQNob3clMjBkbyUyMGklMjB0aHJlYWQlMjB0aGUlMjBicm90aGVyJTIwc3E5MTg1JTIwc2V3aW5nJTIwbWFjaGluZQR0X3N0bXADMTU3NjAwNTQ3Mw--?p=how+do+i+thread+the+brother+sq9185+sewing+machine&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s#id=9&vid=64b3d386b183082abaa9d1d63e50e21e&action=view
Hope this helps.
My needle threader on my machine pinged off when I was sewing its a brotherFS130QCi have the metal bit will it go back on
Hello, Jacqueline -
I am not familiar with the Brother FS120QCi sewing machine. Nor have I been able to find ANY information online about that model of sewing machine.
Therefore, I suggest you locate the authorized Brother sewing machine repair business where you reside, make a phone call, and as one of the repair technicians there about the needle threader for your model of machine.
From information I found on other models of Brother sewing machines with needle threaders, the needle threader is an all-metal or metal and plastic piece which affixes to the machine. You can see images of some sewing machine needle threaders here:
https://tinyurl.com/yb62lm2y
Best wishes.
Brother VQ 2400 can't get needle threader to work. Re-thread machine& changed needle still will not work
What happens when you try to use the threader? Does it miss the needle eye, does it not grab the thread, what?
I need an automatic needle threader for a Brother NS30 Le
You might check out these sites for repair ideas:
Brother NS30 LE needle threader Google Search
otherwise you will need to contact Brother or a sewing repair supply for a replacement part
1helpful
2answers
I changed the needle on my new Brother HE 240 sewing machine and now the automatic threader won't work. Any ideas?
make sure the needle is inserted all the way into the needle holder
also make sure the needle is turned the right way in the needle
holder
2helpful
How do I replace the wire that threads the needle on my brother sewing machine
it would probably be a good idea to take the machine to a sewing machine shop to have the needle threader fixed
3helpful
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
5helpful
2answers
Automatic needle threader on brother se-350
Good luck,
Ginny
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
