George Onyeanusi Posted on Jul 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Solution for konica minolta 250 malfuncion detected c2557
rajeev pal
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 79 Answers
  • Posted on Aug 05, 2017
rajeev pal
Expert
Level 2:
New Friend:
Cheetah:
Answers
79
Questions
Helped
49874
Points
101
C2557 for Toner Density Control abnormality in Developer.
Try in this sequence..
1-Check Toner, if Empty, Reset code and install new toner bottle.
2- if not from above, Then replace Developer and Developing Unit.
3-if Not, then check Hopper Unit, Clean Sensor and Solenoid.
3 Related Answers
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Aug 23, 2009
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Sep 26, 2010
SOURCE: We have Konica Minolta Bizhub 250 What does error
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Konica Minolta Bizhub C220. It has error code C2557 constant paper jam and faint black and white printout
What is error code c2557 on Konica c220?
Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle.
Dec 28, 2010
Error code C2557 - Konica Minolta - Copytechnet
1helpful
How do I solve c2557 error ?
Hi
I found your error code and suggested remedies here:
Error Codes Konica Minolta bizhub 250 Code C2557
This site is very useful as by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a pdf format Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Error code 2557
C2557: Abnormally low toner density detected black TCR sensor.
Detailed Error code explained below.
Possiable solutions.
* Open and close the front toner door.
* Restart the machine by turning off the LCD screen power switch, then by the main body switch located behind the access panel above tray 1 indicator light.
* Call Konica to get a tech out.
C2557 Abnormally low toner
TCR sensor
• When sampling data is determined in TC
ratio calculation control, TCR sensor output
is higher than a predetermined value for a
predetermined number of times in a row
even though there is toner in the sub hopper.
1helpful
Errorc2557
It is my pleasure to guide you.
Konica Minolta 250 Error C2557 is Toner Density sensor problem
Problem: code C2557 - Abnormally low toner density detected Black TCR Sensor
Sounds like something a technician should take care of. Most of the information I could obtain says that the
Solution: Replaced 4038-R729-00 Hopper Drive Assy (C250 part compatible with C252 )
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
6helpful
3answers
We have Konica Minolta Bizhub 250 What does error C2557 mean
2helpful
My Minolta Bizhub-200 prntr. has a C2557 error code. How do I clear it?
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
6helpful
Error c2557 konica minolta 250/NEC IT2530
1helpful
2answers
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
5helpful
Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
