Televison & Video Logo
H
Hardic jain Posted on Jun 25, 2017
Where to download philips led tv firmware for software update
MODEL-22PFL3758
Gerald Gutteridge
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 11, 2019
Gerald Gutteridge
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
8556
Points
48
Software and drivers are available from your local Philips website. Select 'Support' and then you should see the software search facility
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Sep 04, 2008
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
bluegreenash
Gareth Cockram
  • 661 Answers
  • Posted on Oct 04, 2008
SOURCE: Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card
NXP (Philips) SAA713x (SAA7130/SAA7133/SAA7134/SAA7135) reference driver v1.3.4.5:
http://rapidshare.com/files/135230293/S … 5.zip.html
Anonymous
  • 90 Answers
  • Posted on Mar 03, 2009
SOURCE: Philips 42PFL5332D/37B no picture no sound but blue led light on
power supply board is going bad
Mukesh Kumar
  • 3230 Answers
  • Posted on Sep 05, 2009
SOURCE: Is there firmware update for Philips DVDR 3455H ?
Well you get your firmware from below link -
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&session=20090905122441_125.63.122.112&grp=HOME_ENTERTAINMENT_GR&ctn=DVDR3455H/37&mid=Link_Software&hlt=Link_Software
Good Luck!!
Thanks
Anonymous
  • 16 Answers
  • Posted on Nov 02, 2009
SOURCE: I downloaded on my USB the firmware update for my
yes
4helpful
2answers
How to update (firmware) software in Videocon LED 32" DDB tv
how can i update the software of videocon led tv 32''
2helpful
How do i get a software upgrade for my tv
You will need a USB port or SD Card reader on the TV set in order to update the TV's Firmware. (note: some TV manufactures specify what types of memory are compatible with their TV sets i.e. magic gate, etc.)
Use the appropriate storage device for your TV set and go to:
http://www.support.philips.com/support/downloads.jsp?userLanguage=en&userCountry=us
Enter the model number in the search box. It will search for available software/firmware for your TV set. Download it and save it to your storage device.
Insert the storage device into the TV set. If the software/firmware update screen does not come up automatically, select update software/firmware from the TV's menu.
I hope this helps.
How do I upgrade my software?
get a flash drive (blank & formatted)..go to philips web site and see if there is any new firmware offered.for your tv model. if so download to flash drive...shut tv off...plug flash drive to usb port in back of tv....now turn on tv if firmware is need the tv will update (blue or blank screen) before you see a regular picture
1helpful
I have a Phillips LCD tv model #42PF7421D/37. and
I know on the plasma TV's it was a matter of updating or downloading and re-installing the firmware/software for the TV to fix the issue. Go to the following page and if the model you have is indeed a 42PF7421D/37 download the software on the page. Make sure you follow the installation instructions to update the software otherwise the set will become a 150 lb paper weight.
&scy=US&slg=AEN&sct=LCD_TV_SU&cat=TV_CA&grp=SOUND_AND_VISION_GR&session=20091111140139_64.85.227.44&ctn=42PF7421D/37&mid=Link_Software&hlt=Link_Software">Philips Support Page
1helpful
I turn on the gogear sa6045, the loading screan appears and shuts off at 35%.
Reset the player using the pinhole. If it freezes again, you need to update the firmware to resolve the issue permanently.
To update the firmware correctly:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
-Tha Mp3 Doctor
Phillips 4GB
Get the firmware update from the philips website
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
1helpful
Gogear SA5125
enter country
enter model #
click on model #
click on software & drivers
click on firmware upgrade - software
or, just open the Philips Device Manager and click on "Update"
3answers
DOWNLOADING MP3 PLAYER TO WINDOWS VISTA LAPTOP
For Vista compatibility with the SA6045 -
-Tha Mp3 Doctor
2helpful
Software update lcd tv
The Philips 32PFL5522D does support firmware upgrades.
Only the digital board can be updated by the user. This is done by downloading the firmware on to a memory card (CF) and inserting into a PCMCIA adaptor. This is then inserted into the CI slot at the back of the TV.
The main TV would have to be updated by a Philips service agent using a COMPAIR device.
However, I don't think the problem you describe is to do with firmware.
You could try altering the following settings:
  • Contrast - 65
  • Sharpness - 2
  • Contrast Plus - OFF
  • NR - ON
  • Colour - approx 50
If this doesn't help, then the problem is most likely caused by a faulty lead between the LCD panel and driver board. This is a common problem with this model, but should not be an expensive repair.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
