You should be able to get a board but use the board number to find the part not tv number as they use boards in different models and brands
Testimonial: "Hi Russ Wonder if you could help. I had no signal issues and then after I replaced the internal battery the problem was solved but after a while the problem re surfaced.Could it be the input board?"
I would think with not being able to see it, it would be a warn out power board (capacitors)but as it has not stopped working it may just be weak capacitors ie they still working but not holding the right voltage, these are harder to find as you would need to test them independently. or it could be a bad battery this can happen sometimes.
Hi Deodat , have you still got your EC PD300O Television
