My computer has vista but the printer wont work even wen i downloaded the the drivers from HP's website any suggestionsI've tried pretty much everything
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Plz help my computer doesnt work with the printer, i have vista and the printer HP 380
Marnight above has the solution!
Go open: Paint
then: File
then: Scanner or camera
Choose scanner and click when prompted, it will scan right away!
THX
I have hp deskjet f380, and i'm using vista. I need driver for it..
I've been tried to download the driver on hp.com, and guest what, it dosent work at all. (i've been download it about 2 hours..)
Help me please......
I have a windows vista driver for hp deskjet f380. I can send it to you via electronic mail. my electronic mail address is [email protected] Please put in the subject box windows vista hp deskjet f380.
I cant install my printer to my computer nothing i try is working
The printer doesn't work with windows vista home premium edition
I've used the HP Solution Center app that came with the F380 printer to scan without problems on Vista Home Premium 32-bit. However, I do get a message from Vista everytime I print though. It asks if I want to see a message from the printer. Once I click view message, and acknowledge viewing the message, then it prints.
Go to hp.com
check your manufacturers website
SOURCE: HP Deskjet F380 All-in-One Compatible with vista
get the compitable update driver cd from your vista dealer.and install that cd . then it will work properly.this problem is faced by many of the clients using vista .but the compitable update driver cd will solve the problem.
vista home version cannot install (download driver from hp)
I have same problem
I also cannot get my HP f380 deskjet all-in one to install. I downloaded the drivers from the HP website and still cannot install the printer. It just stalls when it comes time to hook up the USB from printer to computer. The computer finds the printer and acknowledges it but then stalls when installing. It just says this will take a couple of minutes but just sits there,stalled. I can't even cancel the operation I have to turn the computer off manually just to stop the installation so I can use my computer.
I have almost the same problem but my printer works and copier but my scanner won't work any solutions?
Have the same problem as everyone else. Have tried so many things, I've lost count. About to give up and buy new printer... can ANYONE help?
have downloaded and works onced an then quites, so i give up; wont print any more online.
printer can not work
I also have a f380, and the vista drivers work good on my desktop computer, including scan function by pressing button. But on my HP Pavilion dv9660eg, the drivers wont even install. The same thing, however, happens with many of HP´s own system drivers for this notebook (and also a printer driver for a Canon printer), so it seems to be a combination of faulty driver and faulty hardware, in my case both related to HP.
printer will scan, but it will not print. i reinstalled it, it is marked ready, the alignment sheet prints, but it won't print.
i have f380 printer but it wont work with my windows vista computer. how can i make this printer compatible with my vista?
joma
I put in a color ink cartridge. Now my printer regis E and will not print at print prompt. I have gone through all the steps provided for updates installing drivers, etc.
wont print keeps telling me its offline
my new p.c have vista and i cant install my hp f380 all-in-one printer
my hp f 380 Deskjet all-in-one printer has stopped working Iv'e cleared all jobs
from the memory and tried to uninstall and reinstall to no avail now the setup
has frozen , My PC is a new Dell inspiron -530 on Vista .
my printer stop printing i have tried most thing even uninstalling and reinstalling the printer driver with the latest driver update but to no avail and i have been using the printer before the os is windows vista
My new pc have vista & I cant install my hp F380 All-in-one printer
I can't download the Hp F380 and have it instell on on computer
I am using a HP laptop and was given a HP Deskjet F380 alll in one printer, scanner etc etc. I have installed all the relevant software, but I cannot seem to print.
I have changed the USB ports in case one was faulty, but they are all in good working order.
When I click on the printer window, it shows all pending jobs, but it will not print my work.
It has printed a self test report so I know it works. It just seems that the printer is not receiving the message form my laptop to print.
What can i do?
The printer won't print
i need driver for vista
i need the softwear of hp deskjet f380 all in one
Can not install the Driver
i need driver for hp deskjet f380 vista
wont work with the hp vista driver
can't print off internet
hi, will need to download HP F380 which is window vista compatible. tks
hp f380 scans and copies fine but will not print. everything goe into que
and when cancelling document must restart computer for document to delete????? was working fine until recently no know updates occured
no power surges or failures occured just stopped working
have downloaded driver from hp website have update driver from website
hp diagnostic tool says printer is not connected to computer but it is
have disconnected and reconnected according to instructions
tried reinstalling from disk error message says "system doesnt meet one or more requirements for installation" "software cannot be reinstalled
using the run as ......command??????
runnibg vista did not have problem till this week will not print from web eny web page
yes that was the same problem that I have using the HP Deskjet F380. previously the printer was printing from the web page, however I installed the software for the scanner and did an update for the printer driver and now this is the problem that I have. I tried the help options but did'nt get me anywhere.
cant print
how can i make hp deskjet f380 compatible to windows vista
first i had problems installing the vista driver for f380 all in one..when i finally did..hp solution centre would not open..i can print a document but cannot scan because the solution center would not open
I have a HP Desk Jet F 380 that will not work with my Windows Vista and when I try too uninstall my desk jet it will not uninstall
me too not able to wrk mine printer in Vista
i have a windows vista laptop and a f380 deskjet unfortunatly it is very tempromental it prints on the odd occaction but then seems to uninstall its self any suggestions ???
My HP380 Deskjet was working well until I installed Vista. Now it will not scan, willnot print but will photo-copy. I ynderstand that one element of driver is missing. I have not been able to re-install this bit of software. Please help.
HP380 desktop printer will not print and scan - but will scan.
f380 doesn't print with windows vista
the same problem pc dont print at internetpage
i have the same problem
I have window vista but it is not taking the driver of HP F380 all in one printer. please give the solution of this and tell me the website or link from where I could download it.
i have same problem
same
Printer wont work with windows vista... even after downloading new drivers from hp website. scanner works though.
the printer doesn't work it will not turn on even thought i didnt do something to it.............
I installed the drivers and it won't even find the printer to add it to my list of printers when I go to print. It just keeps wanting to send it to one note.
i have a hp deskjet f380 but cannot use it on vista ultimate..what can i do
downloaded drivers for vista but download will not complete
not responding the cd for my imprimante hp
Have Vista on my computer and cannot make printer work with this Vista. Even after dowloading drivers.
my driver is not compatible with vista.. wat shud i do?
I have downloaded the Vista software for my HP F380 all-in-one printer and nothing works. All I have is everylight blinking and my computer insisting that the printer is not connected. The USB cable is connected however...nothing. I have attemped all the fixes HP website has listed and still nothing... HELP??
My ViSTA computer has a printer that is all in one. However, it keeps making me align it and it keeps on appearing. Then, when I close it, it refuses to scan my stuff.
All the same, my printer is now a noisey, paper-chewing monster, with lights a flashin, since I got vista (on a hp machine), How poo!
how can i get driver for my printer F380??.. i tired try all driver that i hv download but also can running my printer... another can help me!! that printer can run with xp only. can give me installer that compatible with vista. plz.
i dont have a driver
please send the software of HP deskjet F380 all in one printer because the cd which was given is scrached
my computer has vista but the printer wont work even wen i downloaded the the drivers from HP's website any suggestionsI've tried pretty much everything
