SOURCE: Piston of a ts400 cutquik saw is seized in the housing
What did you expect? Find a engine rebuilder and get ready to spend about 75% of a new replacement.
SOURCE: stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
SOURCE: hi my stihl ts400 will not start no spark plug is
Put a little fuel mix in the plug hole and try to start--it should pop several times. If ok, check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or damage. Make sure the carburetor fasteners are tight. Hope this helps!
SOURCE: Hi, My Stihl ts400 saw
First try a new sparkplug. If no spark disconnect the single wire off the stop switch and trace it back thru the saw and make sure its not chafed anywhere. Do the same with the high tension lead off the sparkplug. If both these are ok the saw has a one piece cdi unit which unfortunately will have to be replaced. Hope this helps, Phil.
SOURCE: Stihl ts400 no spark
I have never seen a flywheel de magnitise, it will be an ignition unit problem
