This error E32 is not such a problem.
It means that the system, responsible for protection against unevenly distributed laundry in the drum, has triggered. All you need to do is open the door, put large and small things evenly, and then additionally run a new spin cycle.
Read the article: How to load things into the drum.
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Testimonial: "thanks-- how do you know how much soap is enough?"
SOURCE: Bosch washing machine
You should find the filter located behind a removable plastic panel at
the bottom front of washer. Unscrew it anti clockwise to remove and
clean it out.
Pl rate me 'very helpful' for the free help,
thanks!
Testimonial: "Had tried that and turned out to be worn brushes!"
