thapabelieve Posted on May 30, 2017
Ahuja ssa-250m service manual - Audio Players & Recorders
Where is Shift Sensor D on my 2003 Ford Explorer v6?
which engine is there 4.0 V6 (DOES ? MEAN V8? 4.6L?
WHO OR WHAT TOLD YOU THE "D' WORD? YES FORD. !
THE REAL FORD NAME IS SSD. SSA TO SSD, A,B,C,D
2wd OR 4wd?
scan the PCM (tcm) see what error you get, and share it here.
the service manual covers all this.
is tranny dead or stuck in gear, PRNDL R and D and L all move car not.
5R55E (or S or W versions used <<< the actual tranny
read how it works and very complex problems.
https://www.sonnax.com/tech_resources/201-18-troubleshooting-tips-for-4r44e-5r55e-transmissions
THE BEST SERVICE MANUAL ON 5R55E IS HERE
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=ATSG++5R55E&_sacat=0
MY GUESS SOLENOID 'D' IS A FORD ONLY NAME.
OF THE 6
4- shift solenoids- Coast clutch / A56421B
1 TCC lock-up solenoid / 56425B
1- EPC pressure control solenoids / 56431
SHIFT LOGIC IS HERE.
5r55e-undefined-undefined-0.jpg SEE MY SECOND PHOTO OF VALVE BODY SSA TO SSD.
Activation for social security
Hello, Gary -
If you are asking about USA Social Security, see the information under the "Activation Code" heading here:
https://www.ssa.gov/employer/ssnvshandbk/access.htm
Best wishes.
2helpful
Why is overdrive light flashing orange when the car warms up and has been driven for about 8 miles?
/D OFF Indicator The instrument cluster receives the O/D OFF indicator status from the PCM over the communication network. When the overdrive function is turned off, the PCM sends a command to the instrument cluster to turn on the O/D OFF indicator. When a powertrain concern exists, the O/D OFF indicator flashes amber and illuminates green when overdrive is selected off. What code ? you said solenoid A -
P0750 SSA SSA Solenoid Circuit Failure SSA circuit failed to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. No reverse gear (short) or no 4th gear (open). MIL on. Go To Pinpoint Test A . P0751 SSA SSA Functional Failure (Stuck Off) Mechanical or hydraulic failure of the shift solenoid. Not all gears present, MIL on. Refer to Diagnosis By Symptom . P0752 SSA SSA Functional Failure (Stuck On) Mechanical or hydraulic failure of the shift solenoid. Not all gears present, MIL on. Refer to Diagnosis By Symptom . P0753 SSA SSA Solenoid Circuit Failure SSA circuit failed to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during on-board diagnostic. No reverse gear (short) or no 4th gear (open). MIL off. Go To Pinpoint Test A . Could be a wiring problem . Did you check the solenoid A wiring circuit back to the PCM ?
Owners manual for ssa -s1d 7800 starsound amp
Try to locate their website, and look for it there.
Pool Heaters
the minimax 250 m manual is the same for the ch model.
Jun 22, 2013 • Pool & Spa
Kitchen Aid Diswasher does not advance to the wash cycle
the hum worries me, from your discription sounds like a wash motor may be bad, or something is blocking the pump from turning, unless your are really handy, i suggest you call for service.
Sears offers what they call and SSA on their 800 # if you buy the SSA it will include the repair you need and a 1 yr warranty. good luck
 Grubhead
Grubhead
SmartAviator
SmartAviator
