"Seltzer water is water that has been infused with carbon dioxide under high pressure, which creates the bubbles," says Toni Marinucci, MS, RDN, a registered dietitian with a master's degree in nutrition and dietetics. "In simpler terms, seltzer is carbonated water therefore the ingredients should just read carbonated water. If it is a flavored seltzer then the ingredients should read: carbonated water, natural flavor."
As long as it doesn't have large amounts of sodium or sugar, you can drink as much sparkling water as regular water - no limits.
SOURCE: Where do I put the
jetblackrave-
In what type of backpack are you trying to use the water bladder? The hydrastorm is most effective in a pack designed for a water bladder. A pack designed for a drinking system willhave two things: 1) a pouch on the inside of the pack that will hold the bladder in a vertical position, against the back, and 2) an opening (usually a small hole on the left/right/or on both sides). A pack without these features can work with a bladder but less effectively. Worst case, you can always make modifications to your pack to make it work with a drinking bladder.
Hope this helps.
DIYpro
Testimonial: "Thank You for your help... My Backpack is the Blackhawk S.O.F. Ruck "
I'm not sure if you ever noticed, but besides the popular 2 liter bottle,
16 fl. oz. bottle, and the 12 fl. oz., can, Diet Coke is also available in the
following sizes:
8 fl. oz. glass bottle
8.5 fl. oz. aluminum can
7.5 fl. oz. mini can
